timing advance (stock distributor)
I’m looking for some stock timing information which obviously can’t be found on the www.
I’ve converted my ´85 F250 w 460 to full EFI package to get some better gas mileage on the daily use.
The information I’m looking for is the original Distributor Advance Specifications for the (standard) part number E3HE-12127-BA with Single Vacuum Advance D3AZ-12370-C which was installed on my truck from the plant.
Im pretty sure this information can be found in shop manuals but before I purchase a shop manual I wanted to ask you guys.
Ashburner- Posts : 92
Re: timing advance (stock distributor)
I have not looked at my shop manual in awhile but, I don't recall it having that information. It will likely show this.
https://www.pittauto.com/customer/piauel/pdf/ford/194-210-86%20Ignition.pdf
Here is a good link with the the mechanical slot information and much more. The hex vacuum canisters are adjustable.
https://www.modmotortech.com/forums/internal-external-engine-22/ultimate-duraspark-ignition-timing-guide-598/
Scott is the distributor Guru here, if he does not chime in you might contact him. He also sells recurved ones.
http://www.reincarnation-automotive.com/Duraspark_distributor_recurve_instructions_index.html
supervel45- Posts : 4498
FWIW I pulled our 1980 3 volume Ford Light Truck Service Manuals and it did not contain that kind information.
Does your 1985 have 2 smog pumps?
» Timing Pointer for Stock Timing Cover
» stock distributor vs msd distributor
» MSD pro billet distributor and fox 460 oil pan timing chain sell
» Distributor sticking in block, can't adjust timing
» BBF parts for sale. mallory distributor, cloyes timing chain
