Valve adjustment order
Valve adjustment order Empty Valve adjustment order
Post  curiousgeorge October 14th 2023, 9:32 pm
Has anyone wrote down the order that the valves can be adjusted using the EO-IC method. If you catch every valve as you come to it you should be able to get everything set in 2 revolutions.
curiousgeorge
Valve adjustment order Empty Re: Valve adjustment order
Post  rmcomprandy October 15th 2023, 9:53 am
curiousgeorge wrote:Has anyone wrote down the order that the valves can be adjusted using the EO-IC method. If you catch every valve as you come to it you should be able to get everything set in 2 revolutions.
Setting all the intakes first then setting all the exhausts on the next go-around ... it will be the firing order; twice.
curiousgeorge likes this post
