Spark plug selection
What, where, when & why? I kind of get it. But I really don’t. Is the point to run as hot of plug for your combo as you can without burning them up? How do you know where to start? How do you know if you need to make a change? I imagine timing, fuel type, power adders all come into play. I’m about ready yo fire my little 466. Solid roller, 10.5, 91 octane. I have
NGK Iridium IX BKR7EIX plugs now. Can’t remember why I chose those.
Also, breaking in with 10/30 & a Premium Carquest oil filter. The parts store guys swear that they are made by Wix. After break in changing oil to 5-30 Lucas Racing oil & a Wix Racing 51515R. Sound about right?
nedceifus- Posts : 118
Re: Spark plug selection
nedceifus wrote:What, where, when & why? I kind of get it. But I really don’t. Is the point to run as hot of plug for your combo as you can without burning them up? How do you know where to start? How do you know if you need to make a change? I imagine timing, fuel type, power adders all come into play. I’m about ready yo fire my little 466. Solid roller, 10.5, 91 octane. I have
What Plugs did Lem recommend?
I would start with them or whatever Ford suggests for Their SCJ Heads.
https://performanceparts.ford.com/download/instructionsheets/FORDINSTSHTM-6049-SCJ.PDF
Looks Like AGSP32C From Their PDF on Them.
supervel45- Posts : 4499
I cant answer all your questions but they taught us in school to run the hottest plug you can for longevity. This is why manufacturers always tend to spec a pretty hot plug. In other words the hotter a plug runs the more it will self clean and burn off deposits. This doesnt apply as much to race cars. Youre more concerned with detonation than how long the plug lasts.
stanger68- Posts : 502
Google Sparkplug Heat Range Conversion Reference Charts "Brands"
Below is the First one I found.
And what Stanger Said.
https://www.ngk.com/heat-range-conversion-chart-2
It sounds like you have the correct plug heat range right now. In NGK a 6 is one step hotter and and 8 is one step colder.
