Run what ya got…….
427John
Price5113
the tree man
Page 1 of 3 1, 2, 3  Next
Run what ya got……. Empty Run what ya got…….
Post  dfree383 November 23rd 2023, 12:24 pm
Welll I’ve decided to put together a BBF with the pieces of Junk I still have laying around gathering rust and dust. Going to go into a 86 mustang with a C6 (have) and 8.8 (already in car)
The parts to start that I have.
Set of crusty D3 heads
One .060 D1 block with a fresh bore.
One offset ground 460 crank
One ATI balancer and a Scat C6 flex plate
One solid Flat tappet Cam Research Cam and a set of old Johnson Solids
various sets of pushrods…. And Rockers
Set of 930-16 comp springs and tool steel retainers
One set of SS 2.19 and 1.71 Valves.
One double Roller Timing Set
One Kaase Oil pump and pick up for 9” deep pan plus ARP drive shaft
One MSD distributor
One Edelbrock Performer intake and a Holley HP
One set of CJ valve covers
I ordered a set of Icon flat tops, 6.800 Scat Rods and a Moroso Fox pan last week.
Let’s have some fun and make some Hp Or ET predictions.
BigBlockRanger and BOSS 429 like this post
Run what ya got……. Empty Re: Run what ya got…….
Post  supervel45 November 23rd 2023, 5:17 pm
Can't Ever Happen, Again Wink
NO CAMSPEC' Suspect affraid S
Oh By The Way "Junk" Is Great and FJB clown
Happy ThanksGiving
dfree383 likes this post
Post  dfree383 November 23rd 2023, 5:32 pm
258/264 .655/.655 on a 108
Post  supervel45 November 23rd 2023, 5:59 pm
I was out wire wheeling the Rusty 4 Link and had a Thought.
Blake Mentioned the other Day Those D2VE Heads He Milled .4"'s into Closed Chamber.
I Never Asked the CC's on Them.
I ASS/UME you are going to be 501-508 Cubes?
With Flat-Tops, One Valve Relief, and.000" Deck or Less You Could Get Some Pretty Serious Compression with Some Tight/Small Chamber Heads.
If You Gut That Fox Down Enough say 28 to 29 Hundren on the Line and Put a Ported Victor and a Dommy on it, With Good Flowing Iron, NO Rules Handicap, I bet Mid to Low 9's Should Not be Very Hard.
^ A Bigger SFT or a Solid Roller would be in Order Though for That.
After What Lane Carney Did at 37000Lbs, Capped Up Tight, I Would Almost Believe "AnyThing" is Possible With These Big Fords, If You Know The Angles
Post  supervel45 November 23rd 2023, 6:01 pm
dfree383 wrote:258/264 .655/.655 on a 108
I* Have Been Thinking of The Lunati Like That, Instead of My 294B8, for The Extra Lift. Smile
Post  69F100 November 23rd 2023, 7:11 pm
6.50s in the 1/8 hp maybe 550
Post  supervel45 November 23rd 2023, 7:29 pm
I am Wondering How "Crusty" The D3's Really Are?
But Yea, if It's Not A Ringer The Above Sounds About Right
Post  supervel45 November 23rd 2023, 9:30 pm
Hey Dave, If You Had say 13/1 Compression and Some Good, as in Very Good Flowing Iron Heads, How Do You Think This Cam Would Go With Some 1.8 Rockers?
Run what ya got……. 20231200
Post  dfree383 November 24th 2023, 9:32 am
Try a few lash cycles and see what it responds too. Then do a
round or two with the rockers. It will tell you what
It wants.
Post  supervel45 November 28th 2023, 8:21 am
dfree383 wrote:Not trying to be a dick, but I was trying to do a specific build thread…….
Would it be possible for you guys to do a Holley tuning thread?
Sorry Dave. No Problem. Carry on with The Build.
If You Want I guess I Could Edit it Out?
You Never Mentioned How Many Cubes?
Post  dfree383 November 28th 2023, 10:53 am
Thank you it’s 510” 4.145 x 4.42
Post  BOSS 429 November 28th 2023, 7:23 pm
You don't scatch the bore you scatch the side of the lifter
and a flat shouldn't really need this
Post  the tree man November 28th 2023, 8:20 pm
I thought the bore was was scored to direct a piddle directly at the leading edge of the lobe as it comes up to the lifter. Since a flat tappet is constantly rotating if the lifter gets the groove that oil stream would be away from the incoming cam lobe most of the time. I can see the benefit to a flat tappet but not so much for a roller. The Comp tool definitely scores the bore and is specific to flat tappets by the description. Maybe I misunderstood.
https://www.summitracing.com/parts/cca-5003
the tree man
the tree man
rmcomprandy likes this post
Post  BOSS 429 November 28th 2023, 8:33 pm
With the valve covers off while priming does oil come out of the push (ALL) rods no matter the position of the rocker? If so there is no need to notch or scatch anything
even 427 or early BOSS 429 with no undercut area lifters I have never seen the need
Post  BigBlockRanger December 12th 2023, 10:12 am
Any luck finding headers?
Post  dfree383 December 12th 2023, 10:52 am
Yeah picked up a set of D&D big tubes
BigBlockRanger and Mark Miller like this post
Post  dfree383 December 27th 2023, 11:28 pm
Man I’m hard core on the fence, recon and port a set of D3’s or buy a some Eddy’s………
The struggle is real!
BigBlockRanger likes this post
Post  BigBlockRanger December 28th 2023, 10:03 am
I am to the point where if i have to grind on a set of iron heads or save a bit and buy an aftermarket head, I will go aftermarket 10 times out of 10.
Post  dfree383 December 29th 2023, 5:42 am
BigBlockRanger wrote:I am to the point where if i have to grind on a set of iron heads or save a bit and buy an aftermarket head, I will go aftermarket 10 times out of 10.
And machine shop prices and turn around time have gone into outer space.
Post  supervel45 December 29th 2023, 5:30 pm
dfree383 wrote:Man I’m hard core on the fence, recon and port a set of D3’s or buy a some Eddy’s………
I hear you on the above about prices and time.
Still It Would be Nice to See a Set of Full Tilt D3's Putting in Work.
Maybe You can score a Set Partially Done Up and Keep the Budget Down.
Those New AFR 280's on Fleebay that just Sold for 24 Something would have been Cool Though for New Aluminum, I Think, Over The Eddie's and What They Say Goes Along with Them, Unless You are Talking Bare Heads? Neutral
Post  dfree383 December 29th 2023, 5:36 pm
I’m not an AFR fan, don’t like the intake port/intake BS.
Plus I have standard valve location pistons and don’t beep like doing additional machine work.
Post  supervel45 December 29th 2023, 5:52 pm
dfree383 wrote:I’m not an AFR fan, don’t like the intake port/intake BS.
10/4
I have not seen the guy on Marketplace for awhile but, he always had good deals on new BBF Eddie's. I guess he was buying display or bleem's with a minor scratch or something. As I recall, he beat Summit by a 100 or more per head.
With the price increases of late (SCJ's Went Up) it's hard not to buy SR-71's and be done with it, Even if you have to build the engine around the heads because they are overkill. At Least That's my Thought on the Matter at The Current Time. Still Have to Notch Though pale
Post  dfree383 December 30th 2023, 2:28 am
10/4
SR-71’s are great heads but they are too big for street strip smaller engines and I don’t have unlimited hood clearance. Bigger isn’t always the best.
Post  dfree383 January 6th 2024, 10:02 am
Build is entering the budget evaluation point……..
Not going to “modify” the D3’s for larger valves and adjustable valve train. Just can justify the $$ in for the return. But they will get it running for future upgrades.
Just going to spring them and do a valve job and run stock rockers with a hydraulic FT cam “for now”
Taking the block out in a few weeks to hone fit the pistons, line home and deck the block, and get the crank balanced, Bob weight came up to 2258. Like stated heads will get a valve job and surfaced.
Will do a update on this in the future probably to TFS streets or Eddy’s, the solid cam I have and a bigger induction system, it would be cool to see how much bang for the buck you get from th top end.
Tally Ho Fellas…..👍🏻
Post  BOSS 429 January 6th 2024, 10:07 am
which hyd stick do you plan on running?
