Water pump?
Water pump?
Did they ever make a reverse rotation water pump for the 460? I am looking to adapt a serpentine system to the big block but the water pump will turn backwards.
curiousgeorge- Posts : 191
Re: Water pump?
curiousgeorge wrote:Did they ever make a reverse rotation water pump for the 460? I am looking to adapt a serpentine system to the big block but the water pump will turn backwards.
NO
Looks Like They (Some Company) Does Now.
Your Going Too Pay Though
https://allamericanbilletstore.com/big-block-ford-cast-iron-429-460-serpentine-system-reverse-rotation-water-pump-w-billet-impeller-as-cast-all-american-billet-1470n/
supervel45- Posts : 4499
Re: Water pump?
Yeah, it looks like I’ll be trying to figure something else out.
Re: Water pump?
curiousgeorge wrote:Yeah, it looks like I’ll be trying to figure something else out.
How about an Electric One or a Moroso Drive Kit. I Don't Know, Just an Idea?
https://www.jegs.com/i/Moroso/710/63750/10002/-1
Re: Water pump?
I actually have 2 of the moroso kits. (Used one to run an alternator) but this is going to be a street car with (hopefully) all accessories working.
Re: Water pump?
What besides the alternator do you need to drive [power steering or air conditioning!!If just the alternator i'm using a modified 5.0 Mustang serpentine water pump pulley IIRC and a 5.0 Mustang Serpentine Crank Pulley that bolts right onto the 460 Harmonic Balancer and i have a standard rotation water pump!!FWIW i'm using a V-6 Contour Dual Electric Fan Set Up now!!
In the pictures above i was using a Modified 3.8 V-6 water pump pulley but like i said above i now have a 5.0 Water Pump Pulley that has the serpentine groves in it the pulley above was smooth no groves the 5.0 pulley works much better no slippage!!
Mark Miller- Posts : 1959
Re: Water pump?
Interesting Threads Using a Marine Waterpump.
https://www.460ford.com/threads/factory-460-serpentine-belt-pullys.158415/#lg=thread-158415&slide=0
Re: Water pump?
There are serpentine systems in the marketplace for a 385 Ford engine using a regular rotation water pump which also use a few idler pulleys in order to make that happen.
curiousgeorge and Mark Miller like this post
Re: Water pump?
Mark Miller wrote:curiousgeorge wrote:Did they ever make a reverse rotation water pump for the 460? I am looking to adapt a serpentine system to the big block but the water pump will turn backwards.
I’m hoping to adapt most of this 4.0 system. Water pump Alternator power steering and air conditioning.
Re: Water pump?
curiousgeorge wrote:Mark Miller wrote:curiousgeorge wrote:Did they ever make a reverse rotation water pump for the 460? I am looking to adapt a serpentine system to the big block but the water pump will turn backwards.
Is the car your working on a 2005 or newer Mustang?
» Water pump for 598
» 460 Water Pump Crossover Tube that goes in the Intake to the Water Pump?
» ANYONE RUNNING THE PROCOMP 35GPH ELECTRIC WATER PUMP--sorry, not proform pump
» Rpm rotating assembly for sale , and misc. take a look
» Water Pump
» Water Pump
