Alan Root Cylinder heads
Alan Root heads for a customers 351W build . How do I identify what cylinder head he has ? Right now I am going of pics and the AR cast in them along With JAF cast in them. They have dual exhaust bolt pattern and looks like 2.02 IN and 1.60 Ex valve size again just going of the pics. I don't have them in hand yet.
Last question are the any good at making HP ?
Thanks Whitefield
Thanks Whitefield
whitefield- Posts : 2244
Re: Alan Root Cylinder heads
whitefield wrote:Alan Root heads for a customers 351W build . How do I identify what cylinder head he has ? Right now I am going of pics and the AR cast in them along With JAF cast in them. They have dual exhaust bolt pattern and looks like 2.02 IN and 1.60 Ex valve size again just going of the pics. I don't have them in hand yet.
Thanks Whitefield
Those sound like the early "K" heads; ("J" heads with bigger valves).
If so, they are not a very good head for that application unless just less weight is your goal; they are fine on a 302.
I agree as some of the earliest aluminum heads offered for a SBF they were great heads for a few minutes but it didn't take long for bigger and better things to come along. One upside to them, is that with the exception of the dual exhaust bolt pattern, they probably resemble a stock casting more than any of the other aftermarket heads. They don't have the big machined flat surface on the end like most other aluminum heads, so when painted engine color they're easy to miss.
427John- Posts : 85
» saw this craigslist ..maybe you guys may want , Aluminum alan root block in NJ ...and heads
» FS: New set of Ford M-6049-SCJA aluminum cylinder heads.. HEADS SOLD, Thx
» New cylinder heads
» Fms cylinder heads
» AFR 315 Cylinder Heads with Top End.
