Eating 2 and 6 rod bearing
Mark O'Neal
Eating 2 and 6 rod bearing Empty Eating 2 and 6 rod bearing
Post  Mark O'Neal August 13th 2024, 1:04 pm
I have a customer with an issue I don't quite get.
4.440 bore x 4.500 stroke ... puller
2 different blocks
2 sets of rods
First crank was a scat, second was an Eagle.
Melling pump
He's eaten 2 and 6 rod bearings three times.
I'm getting a pic of the oil pan, but that seems a each.
Any ideas why, before we throw a bunch of money at it and have the problem repeat?
Mark O'Neal
Eating 2 and 6 rod bearing Empty Re: Eating 2 and 6 rod bearing
Post  rmcomprandy August 13th 2024, 4:46 pm
Mark O'Neal wrote:I have a customer with an issue I don't quite get.
2 different blocks
2 sets of rods
Melling pump
That's the same journal fed oil by two different mains so, it is either not enough side clearance or a radius to chamfer issue or there is something amiss somewhere in the system for that oiling problem to happen like to much main bearing clearance and that journal is just the first to fail ... if everything is balanced correctly.
Post  dfree383 August 13th 2024, 6:27 pm
How high is he spinning it? What journal size and what bearings?
Wet or dry sump? What rods?
Post  BigBlockRanger August 14th 2024, 9:52 am
n/a? turbo? Roots blower? n2o?
Post  Paul Kane August 14th 2024, 10:39 am
2 different blocks
2 sets of rods
Make sure his big truck puller camshaft and roller lifter combination are not such that the skirt of the lifter body is getting raised up so high it momentarily exposes the lifter oil gallery to the crankcase during peak lift, effectively dumping oil back to the pan (down the lifter bores) rather than being sent to its terminal points.
rmcomprandy likes this post
Post  Mark Miller August 14th 2024, 11:46 pm
BigBlockRanger wrote:n/a? turbo? Roots blower? n2o?
I'm guessing N/A since he mentioned it's a Puller but i could be wrong!!
Eating 2 and 6 rod bearing Empty data
Post  hbstang August 15th 2024, 5:01 pm
does he have a data logger to know what the oil pressure is doing during the pull?maybe he needs an a-460 block !
Post  supervel45 August 16th 2024, 7:35 am
2 different blocks
2 sets of rods
Long shot, shot in the dark along the same line. Maybe all off base to.
Have the roller lifters been slot or tick notched to get more oil to the rockers?
If so could they have gotten in the same lifter bores on the second block and the notch's are deeper and they are oiling those rockers more there, instead of those mains?
