Headers
Headers Empty Headers
Post  nedceifus August 28th 2024, 9:03 pm
I know this is not exactly “engine tech”. I am building a 64 Galaxie with a 460. It has a Mustang 2 front suspension & the motor is pushed back about 9”. I’m looking for a 460 header that puts the collectors no lower than the bottom of the oil pan or tranny pan. The BBF Mustang Super Comps I have hang the collector down about 4” lower than any of the drivetrain components. Does anyone know of a header that has these quality’s? I really would like to stick with a long tube pre built header. This car sits LOW.Headers Img_6110
nedceifus
nedceifus
Headers Empty Re: Headers
Post  dfree383 August 29th 2024, 9:31 am
Imo might try some truck stuff or shorties
nedceifus likes this post
Post  nedceifus August 29th 2024, 2:04 pm
Shortys would be the easy button. It’s hard to “try” headers. Some of the pickup headers look good in pictures. I just can’t tell how low they hang in relation to the pans.
nedceifus
nedceifus
Post  BBFTorino August 30th 2024, 3:04 am
Other than hanging too low, do your Hooker Super Comp headers clear everything else, as far as chassis, and steering components?
If so, I'd cut the flanges off and remove the appropriate amount of primary tubing until they tuck up nicely to where you want them, and then weld the flanges back on,
Post  nedceifus August 30th 2024, 1:08 pm
I’ve gone back & forth on this turbo thing. So please forgive me. But I ordered cast exhaust manifolds that will face forward. To fix my header problem I’m just going to go ahead & build a single turbo setup now instead of later.
nedceifus
nedceifus
Post  KaiWolf September 17th 2024, 8:01 pm
This place might have what you need. They made a pair for my T-bird that sits pretty low too.
http://www.fordpowertrain.com/FPAindex/headers2.htm
KaiWolf
Post  rmk57 September 17th 2024, 10:49 pm
Buy a kit and start building your own. I can’t think of a shelf header that would be remotely close to fit a 64 Galaxie with 9” engine setback.
rmk57
Post  RayDav September 18th 2024, 3:30 pm
How about these?  This is a 460/532.  The pipes are a bit oversize.  The collector is 3.5, and had a 3 hole flange.  I narrowed them to 3.0, shortened a bit, and replaced the 3 bolt with V bands.
One pic shows the height of the bottom of the 3.0 head pipe relative to the front part of a rear sump pan.  Ground clearance would not be a problem.  The turbo shown is by #1 cylinder.
https://photos.app.goo.gl/Ti9gaRSY2ha6CXLy8
https://photos.app.goo.gl/ffpKUoifpYfpBXoD6
RayDav
