my line lock no work
does this look like its plumed correct?i have yet to get it to work.i can here the solinoid work when i push the button.
Larry T- Posts : 1076
Re: my line lock no work
did you pump the brakes up and hold it while,,you apply the line loc button,,, or if it is a rebuildable unit,the impeller may be bad ,, just my thoughts
capri-sun- Posts : 346
yes i pumped up the brakes and held the button "no work".the line lock setup was new and wasnt left out in the open so something could get in it.maybe i just need to rebleed the system again it takes 3 pumps to get full pedal.
» will tfs A460 heads work on my d1ve block ? or do they only work on the race blocks
» Getting ready to pull the 429 CJ...Need advice!
» C6 lock-up ?
» Lock it up!
» Line Lock!!
» C6 lock-up ?
» Lock it up!
» Line Lock!!
