Which ARP head bolts do I need for P51s?
Which ARP head bolts do I need for P51s? Empty Which ARP head bolts do I need for P51s?
Post  jbozzelle January 17th 2010, 6:38 pm
Will a stock length work or do they need to be longer? Anybody know the ARP part number I need?
Which ARP head bolts do I need for P51s? Empty Re: Which ARP head bolts do I need for P51s?
Post  Lem Evans January 17th 2010, 7:27 pm
I'm not aware of a ARP bolt kit....takes the stud kit for the BT heads....longer on the exh. side .
Post  jbozzelle January 17th 2010, 10:10 pm
That's what I needed to know.
Do I need to use the 12pt nuts for any clearence issues near the valvetrain? I noticed that using the stock bolts for mockup is a little tight around the rocker stud bosses.
Post  c.evans January 17th 2010, 10:38 pm
John,
What Lem said is correct,,,,and I think it's better to get the 12 pt. nuts. This let's you use a smaller socket, and than the hex nuts. Check for socket clearance to the guide plates. On Randy's P-51 headed engine Lem and I needed to grind a little bit off of the left hand side of the guide plates, and I'll need to do the same with my P-51 headed engine.
Hope this helps,
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  hienergy557 January 18th 2010, 12:16 am
As lem and Charlie said "use the 12 point nuts" I have the normal hex nuts and the socket fouls on the guide plate. I had to torque the head down first, then fit the plates.
It makes it a PITA when was time to do a re-torque.
Cheers Colin.
hienergy557
hienergy557
Post  jbozzelle January 18th 2010, 3:26 pm
Are bolts available in 12pt, or just studs?
Post  rmcomprandy January 18th 2010, 4:41 pm
12 point bolts ARE available from ARP as are smaller 5/8" headed head bolts.
BT heads use a different length bolt/stud araingement than other production based heads.
Post  79must January 20th 2010, 3:18 pm
I used stock bolts with thin washers.It seems fine after 2 years.The exhaust bolts should be longer though.
79must
79must
Post  The Mad Porter January 23rd 2010, 2:56 pm
I use the ARP head bolt kit for the eddy heads. Exhaust bolts are slightly longer. They are 12 point by the way.
Very Happy
The Mad Porter
The Mad Porter
