Its about time!
chuck stevens
The Pope
OldRedFord
Its about time! Empty Its about time!
Post  OldRedFord January 19th 2010, 2:23 am
After a lot of back and forth I have the engine combo nailed down.
Leaves me plenty of room to grow in the future.
Its almost time for me to finally assemble the 460 for my F100.
Heres the engine specs.
For now this is what my engine will consist of
D1VE block out of a Lincoln.
Stock bottom end
Cam 204/214 @ 050, 262/272 adv. 479/504 lift
Valve springs Ford Racing M-6513-A50
Factory rockers
Factory retainers
Headers 1 3/4" primaries
Magnaflow mufflers
Intake factory with autolite spreadbore to holley adapter
Carb Holley 3310 750 cfm
D3VE heads with smog bumps ground down
Roller timing set. Cam timing "straight up"
New rings and bearings.
New oil pump. Stock volume.
Distributor...up in the air...I do have a points one here now for a 429.
Should be good for torque.
Just need a gasket set and to buy the valve springs.
Only other big ticket item I need right now is a radiator. Then all the little crap like spark plugs, wires, hoses etc.
Got the block back from the machine shop today. Its about time! Icon_lol
OldRedFord
OldRedFord
Its about time! Empty Re: Its about time!
Post  The Pope January 19th 2010, 7:33 am
Good deal! Now get started putting that baby together!
The Pope
The Pope
Post  bbf-falcon January 19th 2010, 9:58 am
I have a like new 79 F150 truck radiator if you are interested.
Post  chuck stevens January 19th 2010, 1:02 pm
If you can come across a used, stock, Duraspark distributor...you can swap the gutz to your points distributor...in about 10 minutes.
chuck stevens
http://E-MAIL= stevensracingent@aol.com
Post  IcallhimGeorge January 19th 2010, 1:12 pm
Looks good Tim!
IcallhimGeorge
IcallhimGeorge
Post  69F100 January 19th 2010, 7:34 pm
Tim I think I may have a 302 dizzy out in the barn you could take the insides out and put it in yours it is a duraspark if you need it let me know I will send it to you for the shipping.
Jim
Post  OldRedFord February 17th 2010, 12:46 am
What do you guys think my build will do?
OldRedFord
OldRedFord
Post  longroofracer February 17th 2010, 2:08 am
chuck stevens wrote:If you can come across a used, stock, Duraspark distributor...you can swap the gutz to your points distributor...in about 10 minutes.
Is there some benefit to doing this other than appearance?
longroofracer
longroofracer
Post  bb429power February 17th 2010, 12:06 pm
Sounds great, if this is a street engine then you might want to think about advancing the cam 2 degree's. It isn't enough to drop the rpm range, but it will add some torque and horsepower to it. Nice combination, it will run like a champ.
bb429power
bb429power
Post  chuck stevens February 17th 2010, 12:47 pm
Longroof, the advantage is that you can use any set of gutz in your housing, as long as it comes from an 8 cylinder distributor.
chuck stevens
