87 - ZF 5 Speed & 460 into 75 Highboy? Anyone???
Anyone ever do this conversion. I just got my ZF 5 speed last week & any information would be greatly appreciated.
What we have: It will be going into a 79 F350 on a 75 Highboy Chassis
D1VE block .030
Dished TRW 2404's
Comp Cam .514 - .523
DOVE heads ported per Scott
Comp matched springs
Comp locks & retainers
Comp pushrods.
Edelbrock Performer 460 intake
Holley 750 DP
Dana HP-KP Front 4.10's
Dana 60 Rear 4.10's locked
Will be running 38.5 x 10.50 TSL's for mud & trails
Some Dick Cepek Fun Country II's 40 x 14" Sand & trails.
We will be using this truck to haul the bogger & sand Drag trucks.
It is set up for a NP435 Now & I would like the OD of the 5 speed.
Anyone out there got some bright Ideas? We will start workin on in in a couple weeks.
Here is the truck. Old School Monster truck on 44's
It was restored 15 years ago I saved it form a part out.
.![87 - ZF 5 Speed & 460 into 75 Highboy? Anyone??? 1979F-350001-4](https://2img.net/h/i150.photobucket.com/albums/s116/boulderwallguy/1979%20F350%20Highboy/1979F-350001-4.jpg?t=1264179793)
![87 - ZF 5 Speed & 460 into 75 Highboy? Anyone??? 1979F-350003-1](https://2img.net/h/i150.photobucket.com/albums/s116/boulderwallguy/1979%20F350%20Highboy/1979F-350003-1.jpg?t=1264180154)
![87 - ZF 5 Speed & 460 into 75 Highboy? Anyone??? 1979F-350004](https://2img.net/h/i150.photobucket.com/albums/s116/boulderwallguy/1979%20F350%20Highboy/1979F-350004.jpg?t=1264180210)
D1VE block .030
Dished TRW 2404's
Comp pushrods.
Holley 750 DP
Broncoholic- Posts : 32
Anyone use the ZF? is it a good choice
I am still looking for some info Anybody use the ZF 5 Speed
Re: 87 - ZF 5 Speed & 460 into 75 Highboy? Anyone???
Ollie,
You ought join the Mudslingers group,they may be able see your ?, they might not be interested in reading this section. Go to the top and click on usergroups,then click on the drop down menu to choose the group you want to join. Hope this helps and someone can give you some input +.
Mike
![Wink](https://2img.net/i/fa/i/smiles/icon_wink.gif)
Mike
Thanks Mike I will have to see about that.
I'm using a ZF in my new rebuild.
75 Ford f250 Supercab short bed. I'm building a 429 and putting the 85" ZF behind it and jerking my c6 out.
My machinist cut the extra weight off the stock 85" flywheel and balanced the assembly.
I think I will like the granny and the overdrive. I'm also getting a 400-600 Fitech FI Carb.
75truck- Posts : 102
» Need help swapping a Q-Stick shifter from 3 speed to a 2 speed...
» 77 highboy spring hanger, where to get one?
» Liberty 3 speed or 4 speed
» '77 LTD 460 + ZF 5-speed in a '76 F-350 2WD
» 2 speed junk
» 2 speed junk
