High Flow Dynamics Quick Change Timing Covers Fuel Pump Hex Drives
High Flow Dynamics Quick Change Timing Covers Fuel Pump Hex Drives Empty High Flow Dynamics Quick Change Timing Covers Fuel Pump Hex Drives
Post  Paul Kane January 22nd 2010, 7:03 pm
High Flow Dynamics Quick Change Timing Cover and injector pump Camshaft Hex Drive Assembly. This cover allows quick access for cam timing changes (cover) without removal of the chain case, and a new BBF alternative for cam driven accessories (hex drive).
High Flow Dynamics Quick Change Timing Covers Fuel Pump Hex Drives Gen2cover_02
High Flow Dynamics Quick Change Timing Covers Fuel Pump Hex Drives Gen2cover_01
High Flow Dynamics Quick Change Timing Covers Fuel Pump Hex Drives Gen2cover_06
  • Cast from virgin ingot aluminum
  • Heat treated to 356-T6
  • CNC machined
  • Fits all types of 429/460 blocks (Passenger, Boss 429, A-460, A-96 Aluminum, C & C Motorsports, Eliminator Products, etc)
  • Crank seal is externally servicable
  • Cam timing changes may be made without removing the timing cover (Cloyes Quick Adjust, Pete Jackson & Milodon gear drives)
  • Complete camshaft changes may be made without removing the timing cover (Pete Jackson/Milodon gear drives)
  • Pete Jackson and Milodon gear drives fit under this cover without any modifications
  • Accepts most cam-driven accesories
  • Available in 1.375" Ford snout seal size. Hemi Snout or Rat snout front crank seal fitment machinable
  • Accepts Meziere electric waterpump (when using the Meziere big block Ford w/p spacers).
  • Works in remote waterpump applications, too, such as those offered by Meziere
  • Electric fuel pump or (mechanical injector pump) required
  • May be polished, anodized, painted or powdercoated
  • Modular design. Options/Accessories include cam drive spud & hex drive, blower idler bracket, more (some of these items to be announced/available at a later date).
  • Mounting hardware for case and cover is included
  • Made In U.S.A.
  • $379. Price includes timing chain case, cam gear cover plate, mounting hardware, and instructions.
High Flow Dynamics Cam Driven Hex Drive Assembly
High Flow Dynamics Quick Change Timing Covers Fuel Pump Hex Drives Hexdrive_03w High Flow Dynamics Quick Change Timing Covers Fuel Pump Hex Drives Hexdrive_04w
High Flow Dynamics Quick Change Timing Covers Fuel Pump Hex Drives Hex_drive_installed_1
  • Bolts to existing cam gear (7/16" or OEM 3/8" cam gear bolt versions available, please specify at purchase)
  • Allow's the use of cam-driven injector pumps, waterpumps, etc that may be driven from the front of the camshaft
  • Accomodates 3/8-inch hexagonal driveshaft (not included)
  • Main components are made of surgical grade stainless steel
  • Steel fastener hardware included
  • Works with our Quick Change Timing Cover, Nicson/Hardin Marine cover, or may be used with your modified oem front cover
  • Made In U.S.A.
  • $89. Price includes cam spud, hex drive, cam gear bolt and hardened washer, steel mounting hardware, and instructions.
Package Deal: Quick Change Timing Cover and 3/8" Cam Drive: $450/free shipping in the United States
Call, email or PM if interested.
Thanks,
Paul
