HP to BSFC relation
HP to BSFC relation
I would like to know how much fuel needed for one hp,on the dayno? and how to calculate from BSFC TO HP
thanks 4.72
thanks 4.72
4.72- Posts : 4
Re: HP to BSFC relation
4.72 wrote:I would like to know how much fuel needed for one hp,on the dayno? and how to calculate from BSFC TO HP
thanks 4.72
"Brake Specific Fuel Consumption" is simply the amount of fuel required to make 1 observed, (uncorrected), horsepower.
There is NO set amount which it NEEDS to be for any given engine. It is simply an indication of how efficient the engine is opperating.
i believe this question is Pretty broad for different cam, compression and heads it varies along with elevation and air density and humidity air Temp it all comes in effect when you get that specific.... and no two days or even few hours will be the same....Then you get into the percentage of the load the engine is pulling at any specific time and it will constantly change from minute to minute..... and this is just a few things to look at there are many more......
the Coug- Posts : 3055
