HELP IN NEED FOR 545
HELP IN NEED FOR 545 Empty HELP IN NEED FOR 545
Post  dave d January 26th 2010, 8:09 pm
Hi everyone I'm in need of some advice building a 545 for my 64 comet running a 125 shot of nitrous 4.5 stroke crank and 6.8 rods looking to try to find a good set of pistons don;t know what set of heads I'm running yet this car sees most of its life on the street any suggestions Thanks for all your help
dave d
dave d
HELP IN NEED FOR 545 Empty Re: HELP IN NEED FOR 545
Post  richter69 January 26th 2010, 8:13 pm
How fast you want to go?
How much $$$ you got to spend?
Post  bbf-falcon January 26th 2010, 8:42 pm
Dave, Are you thinking on the line of oem (stock)style, or A or C ? Bout have too know what heads your going to run before ya can figure out the piston deal.
HELP IN NEED FOR 545 Empty 545
Post  dave d January 26th 2010, 8:53 pm
So far this whole car has been done on a budget so I really don't want to stray to far away from that.The best it has run so far 10:93 1/4 muncie,ind. Basic stock rebuild work over iron heads marine cam torker intake eddy carb car weighs in at 3245.Just picked up a rollercam and lifters today but its rpm range is 4400-7800 which would be lots of fun but i drive this car on the street to car shows and outside of town to take my frustrations out after work"poor car".Still would like to drive on street but want low tens.going to swapmeet in columbus how knows what might be there
dave d
dave d
Post  richter69 January 26th 2010, 9:51 pm
Bang for the buck get with Lem on here and get a set of the alum SCJ's he sells and a set of Diamond pistons as well.................
Post  bigjohn2007 January 26th 2010, 10:13 pm
richter69 wrote:Bang for the buck get with Lem on here and get a set of the alum SCJ's he sells and a set of Diamond pistons as well.................
x2
bigjohn2007
bigjohn2007
Post  droppedf100 January 26th 2010, 11:58 pm
Low 10s on motor or spary? Should be easy to achieve on motor with good heads. Really easy on spray.
droppedf100
droppedf100
Post  dave d January 27th 2010, 12:25 am
Low tens motor hopefully 9's with the spray and keep it drivable for street use
dave d
dave d
