4340 eagle crank
4340 eagle crank
Im thinking about buying an 4340 eagle crank that's been turned .010 on the mains. Is there a disadvantage or a problem with this being done. What about bearings to get the correct clearance? An additional .001, would that be .010stdx?
tampa red- Posts : 6
Re: 4340 eagle crank
If it was ground by a competent shop and has been checked out their is no problem getting bearings. Factory Eagle machine work is rather Sloppy and inconsistant for the most part.
dfree383 wrote:If it was ground by a competent shop and has been checked out their is no problem getting bearings. Factory Eagle machine work is rather Sloppy and inconsistant for the most part.
so true plus if it a stock stroke just get a factory cast and run the hell out of it, they are strong as hell....
the Coug- Posts : 3055
Thanks[/quote]
I think that would be correct if the journal is .010. Call Lem Evans to be sure. They may be hard to find in a .010x. King bearings would be your best chance of having it.If they can be found,Lem or Adney can find them. www.bfevansraceparts.com
Thanks[/quote]
The stroke is a 4340 4.500 turned down by eagle. I guess because of a mistake. I'm wondering if the nitride was ground away or do they or did they renitride it?
is it a sell from Eagle or someone have it there handy? if so I would check it out Mic the rods and mains to make sure they are correct and round, as stated some of their work is shoddy at best.... and some is spot on, only way to make sure is double check it..... and ask if the Nitride is on or if they Nitrided it after they ground it! Blake had one of their cast cranks and it was a flexible crank it flexed like a mad man in his engine, I think the 4340 would be alot better.....
