35 spline spool, 9" ford
35 spline spool, 9" ford Empty 35 spline spool, 9" ford
Post  the1969fordguyinky February 8th 2010, 11:14 am
I'm looking to get a 2nd hoghead (3rd member) for the car put together. I have a stock case to assemble it in so I really need a 35 spline spool (or dirt cheap locker) and some 4.56 or so gears.
the1969fordguyinky
the1969fordguyinky
35 spline spool, 9" ford Empty Re: 35 spline spool, 9" ford
Post  DanH February 9th 2010, 2:34 am
the1969fordguyinky wrote:I'm looking to get a 2nd hoghead (3rd member) for the car put together. I have a stock case to assemble it in so I really need a 35 spline spool (or dirt cheap locker) and some 4.56 or so gears.
brand of spool your looking for ? Mark williams is the only 35 spline that fits stock case , i have a used MW --$130 . note: MW spools only fit their axles . Strange and others require 2 1/4 case . have Stange case and 35 spl spool $400 for both and are new
DanH
Post  the1969fordguyinky February 9th 2010, 4:10 pm
No preference on the brand...
I currently have a 35 spline set up in the car, but I got the entire rear end as an assembly. All I did was change the gear out.
I'll have to see what axles are in it.
Thanks for the response!
the1969fordguyinky
the1969fordguyinky
Post  the Coug February 9th 2010, 4:14 pm
i am not for sure but a 35 slpine spool will only fit in a 3.250 case unless you get the chopped version which will fit in a 3.060 case but it is not near as strong as the 3.250....
Post  138 February 9th 2010, 4:27 pm
what kinda numbers will these 3.250 cases hold... got one laying here but was gonna abandon it for a strange eventually
138
Post  DanH February 9th 2010, 4:46 pm
138 wrote:what kinda numbers will these 3.250 cases hold... got one laying here but was gonna abandon it for a strange eventually
if you got a 3.250 case it's aftermarket-- MW/Moser/Strange/HR/FRPP. no stock 9"cases came with 3 1/4 bearings , should take whatever you can throw at it.
DanH
Post  138 February 9th 2010, 5:29 pm
my mistake... I have a factory case.. with the larger 3.063 side bearings. as opposed to the smaller 2.892 size
138
Post  DanH February 9th 2010, 9:48 pm
even the Ford N case can't take it for long , if used with a trans brake . seen the N case brake at the wrong time , only Ford in a 16 car show
DanH
Post  the1969fordguyinky February 10th 2010, 8:54 am
Sounds like a trip under the car for me before I buy anything. Gotta see what I have Wink
the1969fordguyinky
the1969fordguyinky
