What did I do wrong...NPT threading
KY JELLY
falconracer
jones
chuck stevens
OldRedFord
What did I do wrong...NPT threading Empty What did I do wrong...NPT threading
Post  OldRedFord February 11th 2010, 10:37 pm
So I decided to get after the plug in the water jacket of my 460 block that I buggard up.
I drilled it out and got a 3/8-18 NPT tap. Also got a nice brass pipe plug to fit in the hole.
I drilled the hole out to 9/16" According to this chart that is the needed size hole for that tap.
iCrank NPT Thread Tap Drill Size Chart (Inch)
This is the tap I bought
Irwin Taper Pipe Tap, 3/8-18 NPT # 1904P by Irwin Tools
It is a through hole, but threading it to my liking and to the depth a bit greater then the depth of the pipe plug will take about the entire cutting surface of the tap.
So I would run the tap in using a wrench on the end till I could not turn it with my hand, and use a small pipe and go a quarter turn more. Then back off, add more oil and repeat. All went well untill the tap snapped off. Surprised
I had been going completely by hand at first, but when I would feel resistance and take the tap out of the hole, it was barely cutting more thread.
If it makes any difference I am tapping cast iron, and the tap is tapered.
I was expecting it to go much easier.
Picture 1 is drilling out the old plug
Picture 2 is a different angle
Picture 3 shows the stuff the drill press is sitting on so it was at a good height to clear and allow good quill travel.
Picture 4 is the hole ready for tapping and the new plug
Picture 5 is the broken tap.
I am thinking about getting this tool to get the tap out.
MSC Item Detail
What did I do wrong...NPT threading Picture003-4
What did I do wrong...NPT threading Picture001-4
What did I do wrong...NPT threading Picture002-5
What did I do wrong...NPT threading Picture004-1
What did I do wrong...NPT threading Picture005-2
OldRedFord
OldRedFord
What did I do wrong...NPT threading Empty Re: What did I do wrong...NPT threading
Post  chuck stevens February 11th 2010, 10:49 pm
IMHO, first mistake,,,NEVER use oil when tapping cast iron, it MUST be done dry. Oil causes the chips to stick together and to the tap which jambs it in the threads...as you found out. Second, a carbon steel tap will do exactly what happened to you, they are too hard and therefore brittle. Invest in a "high speed steel" tap. Get a second one and cut the first half of the threads off. Start with the full length one, when it bottoms out...switch to the shorty. OR...find a pipe plug that fits the hole you tap better, size varies by manufacturer.
chuck stevens
http://E-MAIL= stevensracingent@aol.com
Post  OldRedFord February 11th 2010, 11:06 pm
High speed steel tap...
Like this?
http://www.amazon.com/Greenfield-Tap-Die-8-18npt-Hi-hook/dp/B002KUBFBQ
OldRedFord
OldRedFord
Post  jones February 11th 2010, 11:23 pm
I agree with Chuck.
Just use a small chisel to knock the tap counter clock wise to get it out. You might have bottomed out the tap.
jones
Post  falconracer February 12th 2010, 12:43 am
heat it with a torch till just a little red then shove a candlestick to it ( don't get burned) let cool then you can stick the ends of needle nose pliers in there and unscrew it right out.
falconracer
falconracer
Post  chuck stevens February 12th 2010, 1:24 pm
Yup, that's a HSS (High Speed Steel) tap. Very Happy
chuck stevens
Post  OldRedFord February 12th 2010, 1:35 pm
I got the broken tap out.
I got my torch and carefully blew a hole about dead center through the chunk of tap. Then I took a screwdriver and a hammer and was able to spin the tap out of the hole by whacking against each of the flutes. I also noted that the block in the immidate area of the hole was still cool to the touch soon after using the torch so I do not think I caused any cracking.
I then went back down to Ace Hardware and got another tap, and a 37/64s drill bit. I looked for a proper sized tap handle but they do not sell one big enough. They sell even bigger tap and dies but do not sell big enough handles to use them?
About this time a guy asked if I needed help and I explaned my situation to him and he said he had also commented a few times about not having tap or die handles as big as the larger taps and dies they sell.
So I bought two cheap 6" adjustable wrenches.
Came back home and drilled the hole out with the bit, and ran the tap in the hole. This time only going one turn forward and then a quarter turn back.
Now my question is...do they make a tapered and a straight pipe plug? The pipe plug only threads in about two threads. I would like for it to thread in a bit farther.
The tap doesnt want to go any deeper and I know I am not hitting bottom. I do not want to break another tap.
Picture #1
The broken off piece of tap. You can see where I torched out the very center.
Picture #2
Threaded hole
Picture #3
Brass plug
Picture #4
Broken off piece of tap, flipped over. If you look close that blue spot is the paint on the engine stand. I do not think I could hit center like that again with a torch.
What did I do wrong...NPT threading Picture001-5
What did I do wrong...NPT threading Picture002-6
What did I do wrong...NPT threading Picture004-3
What did I do wrong...NPT threading Picture006-1
OldRedFord
OldRedFord
Post  KY JELLY February 12th 2010, 1:58 pm
the correct depth to tap is to leave the top 7 threads of the tap out of the hole.
KY JELLY
KY JELLY
Post  jones February 12th 2010, 2:19 pm
Try a different plug. Believe it or not I run across some import pipe threads that don't fit worth a crap. I have especial problems with those types of plugs you are using. Try to find a steel pipe plug and buy a hand full.
I run into this almost every time I need to put a pipe plug in something.
jones
Post  the Coug February 12th 2010, 2:47 pm
justa note I never use a Tap without Magic Tap, they make it both for Cast and Aluminum... make sure you do not use the one for cast on Aluminum it will eat it up.....
Post  jones February 12th 2010, 2:57 pm
I guess I should have told you this earlier but they do make straight taps for blind holes.
jones
Post  the Coug February 12th 2010, 3:04 pm
jones wrote:I guess I should have told you this earlier but they do make straight taps for blind holes.
yep bottom hole taps.....but they do not work on a taper NPT hole.....
Post  OldRedFord February 12th 2010, 4:11 pm
I got a few steel 3/8 npt plugs. Fit much better.
Now for sealing it up, would Permatex thread sealant work?
OldRedFord
OldRedFord
Post  the Coug February 12th 2010, 4:14 pm
yes but make sure it is the soft kind not the perminent
Post  OldRedFord February 12th 2010, 5:09 pm
What is the other allen head plug for on the drivers side of the block, in the side but at the back?
OldRedFord
OldRedFord
Post  Wayne Pearce February 12th 2010, 5:16 pm
The cooling system on your block has two drain plugs. That one towards the rear of the block is also a coolant drain. Better luck with that one.
Wayne (SAWDOFF) Pearce
Wayne Pearce
Post  342g February 12th 2010, 6:01 pm
That one is also a drain plug, hopefully it will come out for you.
342g
342g
Post  OldRedFord February 12th 2010, 7:22 pm
Passage seems blocked off? Tried blowing compressed air in the hole and nothing blew out anywhere.
OldRedFord
OldRedFord
Post  chuck stevens February 12th 2010, 10:34 pm
Left bank coolant drain.
chuck stevens
Post  OldRedFord February 12th 2010, 11:07 pm
Could sediment have blocked that off? If I shine a bright light at the hole and look down from the deck of the block I am not seeing any light shining through.
https://img.photobucket.com/albums/v237/OldRedFord/100_0103.jpg
Not the same block, but the hex head plug is in the same spot.
OldRedFord
OldRedFord
Post  longroofracer February 13th 2010, 8:14 pm
OldRedFord wrote:I then went back down to Ace Hardware and got another tap, and a 37/64s drill bit. I looked for a proper sized tap handle but they do not sell one big enough. They sell even bigger tap and dies but do not sell big enough handles to use them?
They want to sell sets for you to get the handles... oh well. Keep an eye open for them at garage sales and estate sales... everyone looks for wrenches, sockets and expensive stuff, but pass over the less often used, old school, quality tools like these that ole timers had a dozen of.
longroofracer
longroofracer
Post  chuck stevens February 13th 2010, 11:57 pm
Get into that blocked drain hole with an ice pick and screw driver. It's common for the holes to be plugged with rust and silt. Very Happy
chuck stevens
Post  the Coug February 14th 2010, 1:18 am
the question is why are you drilling them out and making them bigger? They are just water drain holes and do nothing but let the water out of the block..... Rolling Eyes
Post  OldRedFord February 14th 2010, 1:54 pm
the Coug wrote:the question is why are you drilling them out and making them bigger? They are just water drain holes and do nothing but let the water out of the block..... Rolling Eyes
Because I tried to remove them to flush out the water jacket and the hex part just rounded out.
OldRedFord
OldRedFord
Post  the Coug February 14th 2010, 2:04 pm
then you should have drilled them out and took a beveled chisel and folded them in and spun it out.... I do it all the time, I have to do it to my spare A-460 block here this next week....
