Lenco trans with air shifter and blanket
Lenco trans with air shifter and blanket Empty Lenco trans with air shifter and blanket
Post  paulie9fingers February 18th 2010, 2:19 pm
I'm listing a Lenco C-S2 transmission for a friend ( same one that has the '63 Falcon, https://www.429-460.com/stuff-for-sale-f1/1963-falcon-chassis-car-turn-key-t3227.htm?sid=33bf0c406d61a84957738ed24d80e3c6 )
Here it is;
* Model C S2
* Current gear ratios
1st - 2.31
2nd - 1.67
3rd - 1.25
4th - 1.00
* Air shifter pods and buttons
* Blanket
$ 4,000.00
Please call Jeff @ 443-695-4219
paulie9fingers
paulie9fingers
Lenco trans with air shifter and blanket Empty Re: Lenco trans with air shifter and blanket
Post  jsracing February 18th 2010, 11:42 pm
How old is it? How many passes since last service?
jsracing
http://indyracingscene.com/?styleid=2
Post  paulie9fingers February 19th 2010, 8:34 am
Please give Jeff a call, it's his transmission and he can answer all of you questions.
Jeff 443-695-4219
*** if you don't want to make the long distance call, pm me your number and I'll have him call you
paulie9fingers
paulie9fingers
Post  bbf-falcon February 20th 2010, 12:08 am
How much would Bell,flywheel,clutch & press/plate cost 4 this setup Question
Post  ThndrChkn February 20th 2010, 3:15 am
bbf-falcon wrote:How much would Bell,flywheel,clutch & press/plate cost 4 this setup Question
Rick, my buddy up here runs a Lenco in his Mustang. His clutch set-up alone was over $1200.00, a bell can cost anywhere from a few hundred to upwards of $1800.00, depending on which clutch you go with. And a flywheel, (depending on if it's aluminum or steel) was like $400.00-$600.00. Then you got all of the linkage parts, and throw out bearing, etc. When we figured mine, we would've been in it a little over $3000.00. Wink
Booooy, I like my Glide. Laughing Laughing
Doug... Cool
ThndrChkn
ThndrChkn
Post  paulie9fingers February 20th 2010, 10:39 am
There ya go, Doug got it covered
paulie9fingers
paulie9fingers
Post  bbf-falcon February 21st 2010, 12:31 am
Thanks Dugger Wink
