DOOE-R heads and other parts
342g
ThndrChkn
Maddmattmustangs
79F350
One set of CJ heads, fresh from machine shop
comes bare but includes the following:
lunati roller springs, part #74726 maybe has 6 runs on them
comp 3/8 guide plates
comp 10 degree retainers
comp 10 degree locks standard height and +.050 height
stud girdle with poly locks
also comes with original valves, retainers, & locks, rocker studs, and guide plates
also has valve seals
$1300.00
Lunati roller cam, part #516A5
Advertised Duration (Int/Exh): 313/324
Gross Valve Lift (Int/Exh): .738/.738
LSA: 110
RPM Range: 5000-8500
@50 duration 282/292
maybe has 6 runs on it
$150.00
Edelbrock Victor intake 4150 pad
carb studholes have been repaired with steel keen-serts
$150.00
Also have stock cj intake iron $150.00
MSD adjustable timing control can change timing up to 15 degress from a knob in the cab $75.00
$1300.00
LSA: 110
$150.00
$150.00
79F350- Posts : 3
Re: DOOE-R heads and other parts
are these the iron heads thanks.
No. They're solid gold. Look at the price.
Doug...
Doug...
ThndrChkn- Posts : 2216
Yea, they are the iron heads, don't say steel, they will beat you down for that also.
342g- BBF CONTRIBUTOR
I am located in central Indiana the zip code is 47841
79F350- Posts : 3
342g wrote:Yea, they are the iron heads, don't say steel, they will beat you down for that also.
Kinda figured as much
are you sure the aren't steel?
'65 T-BOLT- Posts : 1464
'65 T-BOLT wrote:are you sure the aren't steel?
so sure im practically deodorant........god that was cheezy
do you still have the intake
cometbobb- Posts : 2
» My craigslist find ....... 500$ dooe-r heads and other cobra jet parts as well
» WANTED: set of DOOE-R heads.......
» 429 scj DOOE-R heads f/s
» Looking for set of DOOE-R heads....
» DOOE-R heads for sale
