Vacuum Pumps and BBFs
+14
valleydawg
LivermoreDave
342g
Bret Powell
chuck
paulie9fingers
BIGDOG466
18 posters
Page 2 of 2 Previous  1, 2
Vacuum Pumps and BBFs - Page 2 Empty Re: Vacuum Pumps and BBFs
Post  richter69 March 3rd 2010, 10:41 pm
jts557 wrote:I thought about running a electric one just to help get the alky out of the oil dam ederle hat
puts some alky in the pan .And yes its got the right pill it will run within a couple hundreths all day.
Thanks for the info guys
Alky motors need some sort of evac, the electric smog pump deal worked awesome for me. I just put my Moroso 3 vane on because I had it, plan on running only like 5-6" hg.
Post  342g March 3rd 2010, 11:24 pm
About how many inches would you say a smog pump pulls, 5 or 6, I am switching to alky this year, and I got me a smog pump for the condensation problem, hope it works.
342g
342g
Post  richter69 March 3rd 2010, 11:25 pm
You mean the electric deal?
Post  342g March 3rd 2010, 11:27 pm
richter69 wrote:You mean the electric deal?
yes, the one I have is off a 98 blazer.
342g
342g
Post  richter69 March 3rd 2010, 11:37 pm
Take the cover off and make sure the little foam filter is not there.
Mine would pull 5", this was with the engine off, 16volt batt. Put some holes in the big rubber cover and mount it some way it can get airflow though it, they build a lot of heat in the little electric motor, this will help it last a long time.
Post  342g March 3rd 2010, 11:39 pm
richter69 wrote:Take the cover off and make sure the little foam filter is not there.
O.K. that sounds easy enough, thanks for the tips. Laughing
342g
342g
Post  richter69 March 3rd 2010, 11:45 pm
Also put the tank on the suction side of the pump between it and the engine, keeps the mess out of the pump and makes it live longer. Just leave the exhaust side of the pump open, mine never left any oil or water residue anywhere.
Post  342g March 3rd 2010, 11:53 pm
O.K. let it draw through the air/oil seperator right, do you just plug the other valve cover where I had the exhaust evac?
342g
342g
Post  windsor March 4th 2010, 4:21 am
I just saw on another site about using an alternator from an Isuzu diesel, which has a vacuum pump on the back of it. That could be an interesting option, as well.
Vacuum Pumps and BBFs - Page 2 Alternator_Vacuum_Pump
Vacuum Pumps and BBFs - Page 2 DSCF2146
Post  richter69 March 4th 2010, 9:34 am
windsor wrote:I just saw on another site about using an alternator from an Isuzu diesel, which has a vacuum pump on the back of it. That could be an interesting option, as well.
Those little pumps are to work vacuum accessories, not near enough volume for a crankcase evac.
Post  windsor March 4th 2010, 10:21 am
ah, well, I figured since the discussion had moved towards the idea of using much less vacuum (approx 7lbs, etc) than these may work. Like most of my other posts, I have no idea Laughing
Post  342g March 4th 2010, 9:24 pm
John, answer my last question. Laughing Laughing
342g
342g
Post  richter69 March 4th 2010, 10:01 pm
342g wrote:O.K. let it draw through the air/oil seperator right, do you just plug the other valve cover where I had the exhaust evac?
Yes, plug the engine up.............no need to pull air though it, just pulls more oil and such into the take.
At the end of the day I get the motor real hot, shut it off, and while we load everything up I let the vacuum pump run.................I do pull the cap off of the other cover to let it pull air though the engine......unless the humidity st like 100 percent then I just leave it capped...............
Post  342g March 4th 2010, 10:21 pm
Thanks that is what I was planning on doing, but I want to get it right. Very Happy
342g
342g
Post  richter69 March 4th 2010, 10:27 pm
Just some friendly tips from the A+ know it all racer...................... Laughing Laughing
Post  342g March 4th 2010, 10:30 pm
richter69 wrote:Just some friendly tips from the A+ know it all racer...................... Laughing Laughing
You do come in handy, every once in a while. Laughing cheers thanks again
342g
342g
Post  richter69 March 4th 2010, 10:39 pm
n/p................. Cool
