AIR PAN PICS .....
ThndrChkn
AIR PAN PICS ..... Empty AIR PAN PICS .....
Post  bruno March 6th 2010, 2:26 pm
can i get some of yall to post some pics of yalls air pans for the carb...trying to figure out how to mount the air pan ??
thxs
http://WWW.CKRME.COM
AIR PAN PICS ..... Empty Re: AIR PAN PICS .....
Post  ThndrChkn March 6th 2010, 2:36 pm
It's not a great picture Nick, but all I did was cut a hole to fit over the carb, and used the air cleaner base I had for a Dominator & riveted it in place. I bought the air pan foam from Jegs, & with some 3-M M-77 spray adhesive I glued it in place. The hood is all that holds the pan in place.
AIR PAN PICS ..... 022
Doug... Cool
ThndrChkn
ThndrChkn
Post  bruno March 7th 2010, 10:18 am
Looks good Doug thxs for the pics ....
Post  TravisRice March 7th 2010, 10:28 am
Bruno,
I have a few in the engine pics section if you want to search for them. ART has some real nice air bells for making the transition to the carb, I bought some for my 62 project but have not made it that far yet.
Travis
Post  jbozzelle March 7th 2010, 11:31 am
I guess this mean the intake is coming out of the display case?
I'll dig to see if I have some of my old setup. Since you have a cowl hood I'd make it at least that wide and leave it open to draw air in from the rear. That's what I plan to do on mine once the engine shows up in there.
Post  bruno March 7th 2010, 12:30 pm
jbozzelle wrote:I guess this mean the intake is coming out of the display case?
yep its back on the engine ....... have to redo my purge lines and some fuel lines ...
do you guys think drawing the air from the rear is just as effective as a front scoop ??
Post  res0rli9 March 7th 2010, 12:45 pm
some say its better.. like nascar
Post  bruno March 7th 2010, 12:45 pm
i like this hood .......
AIR PAN PICS ..... 4393272847_90b17e8f46_o
Post  bruno March 7th 2010, 12:53 pm
actually that hood is too tall !!!...... i wonder if i could just cut a slot in the front of my hood and build a type of a ram air deal ??
Post  '65 T-BOLT March 7th 2010, 1:30 pm
I believe that will work great,by cutting a hole in the front of your cowl hood.
'65 T-BOLT
'65 T-BOLT
Post  ThndrChkn March 7th 2010, 2:14 pm
In technical terms, an open front scoop will draw in more/better air than a cowl scoop. With a properly built air pan, the "Ram Air" effect is better than that of a cowl induction.
Doug... Cool
ThndrChkn
ThndrChkn
Post  jbozzelle March 7th 2010, 3:13 pm
How tall is your radiator? I plan to put a small Scirocco style radiator in mine. It's short enough to fit below the grill opening which will allow me to fab an air pan from the grill opening to the carb. Sort of like what the PST guys had used on their trucks.
Post  richter69 March 7th 2010, 3:45 pm
Get rid of the radiator...................... Wink No need for it on a heads up car anyway.
Post  bruno March 7th 2010, 8:21 pm
so im really liking this design ...very sleek and it doesnt take away from the lines of the car ....... i will start to mock up the hood tommorrow
AIR PAN PICS ..... IMG_1481
Post  feetfirst March 7th 2010, 9:01 pm
3.5" cowl hood......
AIR PAN PICS ..... P1010933
feetfirst
feetfirst
Post  KY JELLY March 7th 2010, 9:03 pm
nope
KY JELLY
KY JELLY
Post  ThndrChkn March 7th 2010, 11:41 pm
X2 On what KY said. If you look at alot of wind tunnel testing, there's actually not a great deal of air at the opening of a cowl at the base of the windshield. Here's an inside view of mine Nick, after I finished it last spring.
AIR PAN PICS ..... Cid__0618091813
Doug... Cool
ThndrChkn
ThndrChkn
Post  jbozzelle March 7th 2010, 11:54 pm
Stick you some of them NACA ducts on the underside of the cowl. I think Chris Corey has some on his cowl hood.
