Power Disconnect mounting...
Power Disconnect mounting... Empty Power Disconnect mounting...
Post  Coupe Devil March 9th 2010, 11:58 am
I need to install a main power disconnect. The battery is already in the rear. I want to install a pull handle similar to the Flaming River setup to come through the rear as well, and not use the on / off switch mounted through the bumper or rear area around the license plate area.
Can you guys post a pic of where you have yours mounted? I want a CLEAN install that only shows the handle not a long rod coming from out the back of the car..
Brad
Coupe Devil
Coupe Devil
https://www.facebook.com/NCSpeedlab
Power Disconnect mounting... Empty Re: Power Disconnect mounting...
Post  bruno March 9th 2010, 12:22 pm
here you go Brad
Power Disconnect mounting... SBC
http://WWW.CKRME.COM
Post  Coupe Devil March 9th 2010, 4:44 pm
Thanks Bruno. Got any more pics of the inside of the trunk? Is there a seal around the shaft? Mines a street car for a while still so I dont want a lot of water running in the light around the shaft.
Coupe Devil
Coupe Devil
Post  bruno March 9th 2010, 5:31 pm
anytime i washed the car ..never had a leaking issue
Power Disconnect mounting... SBC005
Power Disconnect mounting... SBC006
