small tire craze !!!!
+16
KY JELLY
bigblockfox468
Barney
badnotch
Treeyasoon
LUNCHBOX
511Fox
GTmustang
capri-sun
20 posters
Page 2 of 2 Previous  1, 2
small tire craze !!!! - Page 2 Empty Re: small tire craze !!!!
Post  capri-sun March 13th 2010, 11:36 am
the bash is gonna be like christmas ,,its the anticapation thats killin you i know ,, so you will just have to wait and see!!!!!!!!!! Very Happy Very Happy Very Happy
capri-sun
capri-sun
Post  richter69 March 13th 2010, 11:45 am
bruno wrote:the other issue with the "w" slicks is that when you put these on a 12" and a 14" rim the contact patch widens from 11.2" to 14"s ...big diff from a True 10.5" slick ...but i know you guys knew that already Wink
Wrong, it will not and cannot. The wide rim will ensure all the tread available makes contact...........it can't stretch the tread out, and if it did there is no way it would make 2.8" diff. Your statement is comical and shows what you really know.
You make out like a "w" is an instant 500 hp advantage................its not. If your car hooks on a small tire the larger tire will slow it down.
If it were a bracket race on a marginal track I would say the W tire would have an advantage, it the case of this class at Windy...................nope.
When I had all the traction issues with the c4 the fastest runs the car made were on a Pheonix 29.5 x 10.5...........no "w".
Post  badnotch March 13th 2010, 12:40 pm
i run a 12 inch rim and with the w tire it measured 11.5 and not 11.2 like measured without the rim installed - maybe BRUNO should do some more reasearch before posting crazy CHIT
lmao .... so it did stretch .3"s Razz Razz
badnotch
badnotch
http://www.gnlmotorsports.com
Post  richter69 March 13th 2010, 12:44 pm
badnotch wrote:i run a 12 inch rim and with the w tire it measured 11.5 and not 11.2 like measured without the rim installed - maybe BRUNO should do some more reasearch before posting crazy CHIT
I think he might have meant section width..........which will grow............but aint nuthin' to do with contact patch. I'm sure its something he read someplace anyway...............and you can believe anything you read on the internet........... Laughing
My 31 10.5 W's are on 12" rims, they measure 10.8" at 11 psi if I remember correct.
Post  KY JELLY March 13th 2010, 1:00 pm
one of the guys that runs in the dds with us runs a 10.5 outlaw class and he says he has more traction issues at the end of the track other than the launch. He is running a big huffer though , but I can see where a bump in the track under a big nitrous shot at 130 - 140 mph could cause the same thing. You guys need to be careful running them small tires and big power. Very Happy
KY JELLY
KY JELLY
Post  Doug Rahn March 13th 2010, 1:07 pm
badnotch wrote:got a brand new set doug 10 inches wide
Thanks, but I need to know the diameter at the treads edge specifically for the MT 29.5/10.5-15. The overall diameter in the center of the tread is not a problem, but on my car right at the outside edge could be and issue I want to avoid.
Post  TravisRice March 13th 2010, 1:11 pm
Doug, I can measure mine this evening and post it later on. Mine are true 29.5X10.5 on a 10" wheel. You want to kow the roll out at the edge of the tread and the diameter at the edge??
Travis
Post  Doug Rahn March 13th 2010, 1:13 pm
TravisRice wrote:Doug, I can measure mine this evening and post it later on. Mine are true 29.5X10.5 on a 10" wheel. You want to kow the roll out at the edge of the tread and the diameter at the edge??
Travis
Thanks, the diameter at the edge.
Post  TravisRice March 13th 2010, 2:22 pm
Travis
28 7/8" at the edge of the tread. There you go Douger
Post  richter69 March 13th 2010, 2:35 pm
I was incorrect on the tread width on my 31 10.5w, they measure 11-1/16"
I measured another old set that was dismounted...........11-1/16"
Post  Barney March 13th 2010, 2:42 pm
A 10.5 on a wider rim also stiffens the sidewall for stability down track and limits growth of the tire. Richter is right a big tire takes more power and will be a turd if the car doesnt hit the tires HARD. All of this stock suspension stuff and 10.5 stuff is very cool and impressive, but Im not gonna build another car just to play. My car was built for a big tire and one will always be on it.
Barney
Barney
Post  bruno March 13th 2010, 2:59 pm
I definetly dont make enough power to turn over those super swampers ........
http://WWW.CKRME.COM
Post  Barney March 13th 2010, 3:02 pm
bruno wrote:I definetly dont make enough power to turn over those super swampers ........
I always thought you had the HP market cornered. Laughing
Barney
Barney
Post  bruno March 13th 2010, 3:23 pm
not me .... im just tring to keep up with you guys !!!!
Post  richter69 March 13th 2010, 3:58 pm
all W's are stiff walls...except the 28 10.5w if I remember correct.
Post  Barney March 13th 2010, 6:31 pm
richter69 wrote:all W's are stiff walls...except the 28 10.5w if I remember correct.
I believe you are correct all Ws are Stiffies.
Barney
Barney
Post  Barney March 13th 2010, 6:32 pm
bruno wrote:not me .... im just tring to keep up with you guys !!!!
If you lay down a clean spray pass it would make me look stupid.
Barney
Barney
Post  Stangman98 March 13th 2010, 6:54 pm
bruno wrote:here is a pic for you Nevs Razz
small tire craze !!!! - Page 2 Motivatorcd76fc45fba44dee04d11ccfd2
Stealing my photo Bruno?? Twisted Evil
Small tire racing is great. I think it takes more work to get the suspension, weight distribution ect. set up on those cars then a W tired car
Stangman98
Stangman98
http://www.racestangs.org
Post  bruno March 13th 2010, 8:08 pm
stay out of this D Twisted Evil ......
btw ....... thxs Laughing
Post  jmayabb March 13th 2010, 9:47 pm
I need to measure but I think my MT 29.5 X 10.5 tires measure 10.2 on a 12" rim.
jmayabb
jmayabb
http://www.joesraceparts.com
Post  bruno March 13th 2010, 10:26 pm
jmayabb wrote:I need to measure but I think my MT 29.5 X 10.5 tires measure 10.2 on a 12" rim.
Joe are you gonna try and make it to the bash this year ??? i would love to be able to put a Hemi on the trailer Razz Razz cheers
Post  DILLIGASDAVE March 14th 2010, 7:24 am
bruno wrote:when you put these on a 12" and a 14" rim the contact patch widens from 11.2" to 14"s
Sounds like the same magical "fuzzy math" politicians love. Razz
Big big power & a tiny tiny tire calls for a Davis traction controll, or at least a Digital 7. Without one or the other, another good investment is extra racing seat covers.......just incase turd stains ruin the old seat cover from the butt pucker effect. Laughing
Don't hate on the W's, just think of them as a little extra safety insurance. Twisted Evil
Post  Doug Rahn March 14th 2010, 8:38 am
TravisRice wrote:
Travis
Thanks, I'll check it out this morning!
Post  jmayabb March 14th 2010, 9:59 am
I would like to bring the car but I can't say for sure. If I do, I will bring a rope so your car can see what it's like to go fast. Very Happy
Just kidding Nick. Is Friday test and tune?
jmayabb
jmayabb
Post  bruno March 14th 2010, 5:25 pm
I know Joe ..... yep TnT is Fri ... i really hope you guys make it would love to finally met you and the car Wink
