xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
+11
bronco
johndickjr
86 coupe
tiger
new2460
JohnnyG
nuclearcobra
patfromjersey
ThndrChkn
15 posters
Page 2 of 2 Previous  1, 2
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx - Page 2 Empty Re: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Post  Lem Evans March 1st 2010, 11:06 am
In stock!!
Post  patfromjersey March 3rd 2010, 11:39 pm
Lem Evans wrote:The FRPP site says....4,750 peak tq./ 6,000 peak Hp .
There is not one answer i.m.o. the size of the engine and cyl. head used will vary results.
Not only a shameless bump for Lem on this great cam, but my 521/SCJA Headed/G460 Intake (Victor)/Quick Fuel 950 combo with this cam, pulls hard to 6500rpm's, and shifting at anything less, resulted in slower times at the track, for my 3850 lb. street ride. Smile Great price too! Cool
patfromjersey
patfromjersey
Post  johndickjr March 6th 2010, 9:38 pm
what springs are you guys running on this cam
johndickjr
Post  Lem Evans March 7th 2010, 12:12 am
most of them got FRPP A351
Post  Lem Evans March 21st 2010, 10:44 am
In stock.
Post  bronco March 22nd 2010, 6:15 pm
lem, would this work in stock cj heads and 60 over domed pistons.unless i can find a set of 030 flat tops cheap. truck is for pulling and mudbogging. 410 gears with 39.5 boggers. weight should be around 4000 lbs or more.thanks,kyle
bronco
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx - Page 2 Empty cam and springs
Post  spoon5 March 22nd 2010, 8:17 pm
How much for cam and springs. THANKS EARL
spoon5
Post  Lem Evans March 23rd 2010, 12:11 pm
Depends on the application.....most flat tappet spring packages are $125-$140.
Post  Lem Evans April 13th 2010, 8:50 pm
In stock Exclamation
Post  Lem Evans May 4th 2010, 11:25 am
tttttttttttttttttttt
Post  Lem Evans May 18th 2010, 11:28 am
Lem Evans wrote:In stock Exclamation
Post  Lem Evans June 14th 2010, 7:32 pm
Cheap Exclamation
Post  Blackcoupe June 21st 2010, 9:56 pm
Thanks for the cam, showed up today, box and everything in perfect condition. I'm really really close to this thing making some noise.
Thanks again,
Marvin
Blackcoupe
Post  Lem Evans July 4th 2010, 3:11 pm
Thx....Marvin.
Post  Lem Evans July 13th 2010, 6:48 pm
cheers Cheap
Post  1BADBIRD July 24th 2010, 10:07 am
This is a great cam for the street or the strip . I run it in my big block TBird and drive to the strip , blow off a couple of 11.50's and then drive home .
1BADBIRD
1BADBIRD
Post  res0rli9 July 24th 2010, 2:35 pm
about what stall converter would a 466 with ported D3s C6 3.70-3.89 rear and about 2900lbs.need for the street and a few times to the track?
mostly street.
Post  Lem Evans July 28th 2010, 12:19 pm
I'm not sure about the converter........maybe pose the question in the tech section.
Post  Lem Evans July 28th 2010, 12:20 pm
We bought the last C460 cam FRPP had yesterday...........when it's gone that's the end of this offer Crying or Very sad
Post  Lem Evans August 12th 2010, 6:32 pm
Post  Lem Evans August 21st 2010, 7:05 pm
One left.
xxxxxxxxxxxxxxxxx
Last edited by Lem Evans on September 1st 2010, 10:19 am; edited 1 time in total (Reason for editing : all are gone)
