9" gear setup. Is this an acceptable pattern?
9" gear setup.  Is this an acceptable pattern? Empty 9" gear setup. Is this an acceptable pattern?
Post  Greg_P March 16th 2010, 2:03 pm
These are used 4.11 gears with low miles (like 200 or less miles) on them. They ran quiet in another centersection.
I have set them up and to the best I can, but if the pattern is iffy let me know and I'll keep working on it.
Right now I am running a .011" shim set and .008" backlash.
Thanks for any advice, I want these gears to run quiet.
Greg
Drive:
9" gear setup.  Is this an acceptable pattern? 100_3911
Coast:
9" gear setup.  Is this an acceptable pattern? 100_3912
Greg_P
Greg_P
9" gear setup.  Is this an acceptable pattern? Empty Re: 9" gear setup. Is this an acceptable pattern?
Post  richter69 March 16th 2010, 4:51 pm
run it..............
Post  Greg_P March 16th 2010, 7:43 pm
Well I fukked with it again. Ended up with what might be better?
9" gear setup.  Is this an acceptable pattern? 100_3913
9" gear setup.  Is this an acceptable pattern? 100_3914
Greg_P
Greg_P
Post  kjett March 16th 2010, 8:29 pm
Looks good to me, run it till ya rip the teeth off! Very Happy
kjett
kjett
Post  DILLIGASDAVE March 18th 2010, 12:26 am
The drive pattern in the second pic (after you fukked with it again) looks much better, it has a stronger contact & looks much less like a "ghost" imprint. If it was a drag only car you might want to move the drive pattern down a little closer to the toe. If it was a street only car you could move the drive pattern up a little farther towards center. But for a street/strip car that current drive pattern looks like a damn good compromise. Wink
Post  Greg_P March 18th 2010, 12:31 pm
Thanks a lot, guys!
Greg
Greg_P
Greg_P
