4.5 stroke how high Rpm
+10
Mark O'Neal
511Fox
Tore
14 posters
Some of you guys that run a 4.5 stroke crank how high do you wind them?
Thanks Tore
Thanks Tore
Tore- Posts : 865
Re: 4.5 stroke how high Rpm
You wouldn't believe me if I told you...
Nevs- BBF CONTRIBUTOR
I've been over 6500 with mine with no problems, and I know there are several that regularly go over 7000.
schmitty- Posts : 4538
Depends on how good the heads and manifold are and how the engine is camed....as in how high does the engine want to go. The engine block oiling system is also a consideration. Many different answers.
I'm hoping my new one will zing like a small block!
Curt- Posts : 2791
Bigger Is Better?
Thought the longer the crank the lower the RPM had to be am I missing something
511Fox- Posts : 251
I shift mine at 71-7200 rpm.
Wherever it's gotta go........
I used to use the "Yukon Jack" rule.
7,500 if you're winning, 8,200 if you're losing........
Mark O'Neal- Posts : 286
511Fox wrote:Thought the longer the crank the lower the RPM had to be am I missing something
depends on the cam and cyl head package................
richter69 wrote:511Fox wrote:Thought the longer the crank the lower the RPM had to be am I missing something
It really depends upon the weight of the reciprocating assembly as to what is considered OK. 90 feet per second is usually considered safe in a DRAG race engine if the reciprocating weight is under 1,100 grams; 75 feet per second piston speed in an endurance type engine.
I was commenting mainly on the applications ability to breath at a given rpm............and yes weight also plays a role.
Mark O'Neal wrote:Wherever it's gotta go........
X2
hayhauler- BBF CONTRIBUTOR
I shift mine at 6800 go through the lights in the 1/8th at 7-7100. Turned it 7800 once by accident ( thank goodness for high side chips), but it was still pulling pretty good.
BigDave65- Posts : 567
RPM
I roll through the traps at about 7200 with my 605. I would prefer to shift it at 6800 or 6900 and cross the finish line at 7,000 or less. Before I swapped to a 4.29 gear (from 4.56) it crossed at about 7,350. It goes faster with the lower RPM.
A couple of years ago, it saw 9,000 rpms for a fraction of a second due to a broken ring and pinion. The only problem was eight bent exhaust valves. The high side chip was out....grrrr.
Keith
Keith
» forged .030 over pistons 460 stock length rod and stroke . for dove heads high compression
» Does a high volume oil pump necessitate a high volume oilpan?
» 4.75.stroke
» stroke
» stroke
» 4.75.stroke
» stroke
» stroke
