need 460 info and specs
I have a 76 f-150 4x4, with a stock 460, according to what i can find online, the Y in the vin means it came with a 360. I'd like to know what year my 460 is, and the plugs and gap it takes. also would like to decode the door plate build codes. does anyone know this info? or know a website where i can find this info? my searches have not been successful. thanks
kevstang- Posts : 3
Re: need 460 info and specs
THIS IS WHAT I FOUND FOR PART #'S
PART NUMBER DECODE
Section 1 Section 2 Suffix Note
D1ZE 9424 C
First Character
Year
C=1960
D=1970
E=1980
F=1990
etc.
Group Number
1000-1999=Wheels/hubs/drums
2000-2099=Brakes
2001-2200=Brake shoe and lining
2100-2399=Brakes
2400-2999=Brake pedals/linkage
Engineering Revision
Left/Right
Color
Second Character
Year in the decade
3000-3499=Front axle/ft. suspension
3500-3599=Steering gear
3600-3999=Steering Wheel/column
Third Character
Car line
A=Full size/Galaxy
B=Bronco (70-75)
C=Torino/Elite
D=Falcon (60-69)
F=Outside US
G=Comet (61-68)
Montego (69-76)
H=Med./Heavy Truck
J=Industrial
L=Lincoln(58-60)
M=Mercury
O=Fairlane (62-68)
Torino (69-76)
R=Capri
S=Thunderbird
T=Truck
U=Lincoln(61-up)
V=Lincoln
W=Cougar
Z=Mustang
HM=Holman-Moody
3A635=P/S kit
4000--4599=Rear axle
4600-4999=Driveshaft
5000-5199=Frame
5200-5299=Muffler
5300-5399=Front springs
5310=Spring chart
5400-5999=Stabilizers
6000-9999=Engine ID tag/pulley ID chart
6900-7999=Manual trans-exc. linkage
7000-7299=Manual trans linkage, etc
7300-7499=Manual trans linkage, etc
7500-7999=Clutch
7000-7999=Auto trans - exc. linkage
7000-7199=Auto trans linkage, cooling, etc
7200-7399=Auto trans linkage, etc
7400-7999=Auto trans linkage, etc
8000-8499=Radiator, grill, cooling
8500-8599=Water pump
8600-8999=Fan
8620=Drive belt chart
9000-9299=Fuel tank & lines
9300-9399=Fuel pump, gauge
Forth Character
Series code
A=Chassis
B=Body
E=Engine
M=Motorsports
X=Muscle Parts
Y=Lincoln/Mercury
Z=Ford Parts & Service
9400-9499=Manifolds, t-stat, emission
9500-9599=Carburetor
9500-9999=Carb parts/lists
9600-9699=Air cleaner and related
9700-9999=Choke, accelerator, speed control
10300-10599=Alternator, pulleys, mounting
10600-10999=Battery, instrument cluster
11000-11999=Starter, ignition, headlamp sw
12001-12999=Coil, distributor, plugs
13000-13999=Headlamps, parking ,turn ind.
PART NUMBER DECODE
D1ZE 9424 C
First Character
Year
C=1960
D=1970
E=1980
F=1990
etc.
Group Number
2000-2099=Brakes
2100-2399=Brakes
Left/Right
Color
Second Character
Year in the decade
Third Character
Car line
A=Full size/Galaxy
B=Bronco (70-75)
C=Torino/Elite
D=Falcon (60-69)
F=Outside US
G=Comet (61-68)
Montego (69-76)
H=Med./Heavy Truck
J=Industrial
L=Lincoln(58-60)
M=Mercury
O=Fairlane (62-68)
Torino (69-76)
R=Capri
S=Thunderbird
T=Truck
U=Lincoln(61-up)
V=Lincoln
W=Cougar
Z=Mustang
HM=Holman-Moody
3A635=P/S kit
5000-5199=Frame
5200-5299=Muffler
5310=Spring chart
7500-7999=Clutch
8600-8999=Fan
Forth Character
Series code
A=Chassis
B=Body
E=Engine
M=Motorsports
X=Muscle Parts
Y=Lincoln/Mercury
1. First three characters - F10 - Truck Series Code
F10 - F100 2 Wheel Drive
F11 - F100 4 Wheel Drive
F14 - F150 4 Wheel Drive
F15 - F150 2 Wheel Drive
F25 - F250 2 Wheel Drive
F26 - F250 4 Wheel Drive
2. Fourth character - A - Engine Code
A - 6 cyl - 240cid - 1BBL carb - 1973-74
B - 6 cyl - 300 cid - 1BBL carb - 1973-80
G - V8 - 302cid - 2BBL carb - 1973-80
H - V8 - 351cid - 2BBL carb - 1973-80
Y - V8 - 360cid - 2BBL carb - 1973-76
H - V8 - 390cid - 2BBL carb - 1973-76
M - V8 - 390cid - 4BBL carb - 1974-78
S - V8 - 400cid - 2BBL carb - 1977-80
J - V8 - 460cid - 4BBL carb - 1973-80
3. Fifth character - U - Assembly Plant Code
B - Oakville, Ontario, Canada
C - Ontario, Canada
E - Mahhaw, NJ
H - Lorain, OH
I - Highland Park, MI
K - Kansas City, MO
L - Michigan Truck
N - Norfold, VA
P - Twin Cities, MN
R - San Jose, CA
S - Allen Park, MI
U - Louisville, KY
V - Kentucky Truck
4. Remaining six characters - 100001 - This is a numeric code for the vehicle build sequence. In some cases there could be two letters and four numbers.
C - Ontario, Canada
E - Mahhaw, NJ
H - Lorain, OH
K - Kansas City, MO
L - Michigan Truck
N - Norfold, VA
P - Twin Cities, MN
R - San Jose, CA
S - Allen Park, MI
U - Louisville, KY
V - Kentucky Truck
DOOR PLATE CODES
F-150:
19 – 3.55 Non-LS
18 – 3.08 Non-LS
H9 – 3.55 LS
B6 – 3.73 LS
F-250:
27 – 3.31 Non-LS
26 – 3.73 Non-LS
Ranger:
84 – 3.45 Non-LS
86 – 3.73 Non-LS
87 – 4.10 Non-LS
89 – 4.56 Non-LS
F6 – 3.73 LS
F7 – 4.10 LS
92 – 3.08 Non-LS
R5 – 3.55 LS
91 – 3.27 Non-LS
96 – 3.73 Non-LS
R6 – 3.73 LS
Transmission Codes:
U – Automatic 4R70W (F-150, F-250)
E – Automatic E4OD (F-150, F-250)
M – 5 speed manuaoverdrive (F-150, F-250, Ranger)
D – Automatic 5 speed (Ranger)
T – Automatic 4 speed (Ranger)
Spring Codes
The following lists available spring codes.
Front Springs
1 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250, Explorer/Mountaineer)
2 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250, Explorer/Mountaineer)
3 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
4 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
G — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
8 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
9 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
Z — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
T — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
U — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
6 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
C — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
E — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
F — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
B — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
D — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
E — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
F — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
G — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
H — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
J — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
L — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
P — automatic ride contro(Explorer/Mountaineer)
A — 5310 spring (Econoline, F-150, F-250, Ranger)
B — 5310 spring (Econoline, F-150, F-250)
C — 5310 spring (Econoline, Ranger)
D — 5310 spring (Econoline, Ranger)
E — 5310 spring (Econoline, Ranger)
F — 5310 spring (Econoline, Ranger)
G — 5310 spring (Econoline, Ranger)
H — 5310 spring (Econoline, Ranger)
J — 5310 spring (Econoline, F-150, F-250)
K — 5310 spring (Econoline, F-150, F-250, Ranger)
L — 5310 spring (Econoline, F-150, F-250)
M — 5310 spring (Econoline, F-150, F-250, Ranger)
N — 5310 spring (Econoline, F-150, F-250, Ranger)
P — 5310 spring (Econoline, F-150, F-250)
R — 5310 spring (Econoline, F-150, F-250)
S — 5310 spring (Econoline, F-150, F-250)
T — 5310 spring (Econoline, Ranger)
U — 5310 spring (Econoline)
V — 5310 spring (Econoline)
W — 5310 spring (Ranger)
Z — 5310 spring (Econoline)
Rear Springs
6 — 5560 spring (Econoline)
7 — 5560 spring (Econoline)
C — 5560 spring (Econoline, F-150, Ranger)
E — 5560 spring (Ranger)
N — 5560 spring (Econoline, F-150)
P — 5560 spring (Econoline, F-150)
R — 5560 spring (Econoline, Ranger)
S — 5560 spring (Econoline, Ranger)
T — 5560 spring (Ranger)
X — 5560 spring (Ranger)
G — 5560 spring (Econoline, F-150)
K — 5560 spring (Econoline, F-150, Ranger)
A — 5560 spring (F-150)
B — 5560 spring (F-150)
D — 5560 spring (F-150)
F — 5560 spring (F-150, Explorer/Mountaineer)
H — 5560 spring (F-150, Explorer/Mountaineer)
J — 5560 spring (F-150)
L — 5560 spring (F-150, Explorer/Mountaineer)
1 — 5560 spring (F-250)
2 — 5560 spring (F-250)
3 — 5560 spring (F-250, Ranger)
4 — 5560 spring (F-250)
X — 5580 spring, load-leveling suspension (F-250)
Y — 5580 spring, load-leveling suspension (F-250)
Interior Trim Codes
The following lists the interior trim and interior color codes:
Interior Trim
A — Hampton vinybucket seats — Econoline
E — Camden cloth captain chairs — Econoline
C — Stockton vinybucket seats — Econoline
F — Kirk cloth captain chairs — Econoline
A — vinyfulbench seat (split back), vinyfulbench (Mexico) — F-150, F-250
C — polyknit fulbench seat (split back), polyknit fulbench (Mexico) — F-150, F-250
F — cloth captains chairs with console — F-150, F-250
H — leather captains chairs with console — F-150, F-250
M — cloth 40/60 bench seat — F-150, F-250
E — leather 40/60 bench seat — F-150, F-250
A — vinybucket seats (Explorer)
J — cloth premium bucket seats (Explorer/Mountaineer)
Z — cloth sport bucket seats (Explorer/Mountaineer)
G — cloth sport bucket seats — less power (Explorer)
F — leather sport bucket seats (Explorer/Mountaineer)
M — cloth split bench seat (Explorer)
1 — limited leather sport bucket seats (Explorer)
H — simulated split vinybench seat (Ranger)
E — Cirrus cloth 60/40 split bench seat (Ranger)
G — Triad luxury sport bucket seats (Ranger)
Interior Color Codes
X — Medium Prairie Tan (F-150, F-250, Explorer/Mountaineer, Ranger)
2 — Medium Graphite (Econoline, F-150, F-250, Explorer/Mountaineer, Ranger)
S — Willow Green (F-150, F-250, Explorer/Mountaineer, Ranger)
D — Denim Blue (Econoline)
P — Mocha (Econoline)
N — Cordovan (F-150, F-250)
E — Dark Denim Blue (Explorer/Mountaineer, Ranger)
Tape Stripe Codes
B — Silver/Red — Econoline (Chateau)
C — Light Teal/Red — Econoline (Chateau)
D — Medium Silver/Red — Econoline (Chateau)
H — Silver Metallic/Heliotrope (F-150, F-250) 4x2
2 — Ebony/Amethyst (F-150, F-250) 4x2
T — Silver Metallic/Medium Titanium (F-150, F-250) 4x4
5 — Ebony/Graphite Sparkle (F-150, F-250) 4x4
R — Silver/Dark Toreador — upper, Dark Toreador/Silver — lower (F-150, F-250 Lariat)
8 — Dark Blue/CoraPeach — upper and lower (F-150, F-250 Lariat)
9 — Bright Green/Pacific Green — upper, Pacific Green/Bright Green — lower (F-150, F-250 Lariat)
S — Silver/Ebony/Silver — upper, Ebony/Silver/Ebony — lower (F-150, F-250 Lariat)
C — Light Prairie Tan/Heliotrope (F-150, F-250) 4x2
F — Light Prairie Tan/Medium Titanium (F-150, F-250) 4x4
V — Violet Metallic kit (Explorer XLT)
W — Light Willow kit (Explorer XLT)
R — Medium Santa Fe kit (Explorer XLT)
P — Platinum kit (Explorer XLT)
G — Anniversary Gold (Mountaineer)
P — Oxford White/Platinum (Mountaineer)
R — Toreador Red/Platinum (Mountaineer)
W — Medium Wedgewood/Platinum (Mountaineer)
Y — Pacific Green/Platinum (Mountaineer)
U — Ebony/Platinum (Mountaineer)
0 — Light PearGold Metallic (Explorer Limited)
1 — CharcoaGreen (Explorer Limited)
2 — Desert Violet (Explorer Limited)
3 — Ebony (Explorer Limited)
P — Platinum (Ranger XLT "Off Road")
S — Silver (Ranger XLT "Off Road")
B — Blue/Dark Blue (Ranger XLT)
C — Copper/Gold (Ranger XLT)
G — Green/Gold (Ranger XLT)
T — Tea(Ranger Splash)
V — Violet (Ranger Splash)
4 — Silver/Medium Graphite (Ranger SE/LE)
5 — Beige/Brown (Ranger SE/LE)
8 — Santa Fe/Woodrose (Ranger SE/LE)
my door tag codes
WB-133
COLOR-8
TYPE-F150
BODY-DG4
TRANS-G
AXEL-14J
DSO-28
I appreciate the help and any more you can give, leaving for work, so probably be tomorrow before i can get back on. Thanks
WB-133
COLOR-8
TYPE-F150
BODY-DG4
TRANS-G
AXEL-14J
DSO-28
kevstang- Posts : 3
WOW copy and paste got you covered.
nice Bruno
nice Bruno
the Coug- Posts : 3055
» Ignition timing with SCJ heads
» Need Help build questions
» cam specs for bbf
» Got another cam, need specs
» help with cam specs
» cam specs for bbf
