ford 9 inch part needed
i need a bolt and nut like in the picture....it bolts the backing plate on, or where i can get one from. thanks
duff429- Posts : 202
Re: ford 9 inch part needed
check with your local ford dealer or with lem
Ford Racing part # M 4002-B for a set of 8 in 3/8" size.
The small bearing housing ends use 3/8 T bolts.
The large bearing ends use 1/2" T-bolts. I'm not sure if Ford still has those, but you can get them aftermarket:
http://www.moserengineering.com/brakes/part-812tk-1-2-t-bolt-kit.html
its for my 9 inch out of my 70 cyclone, so the 3/8 will work. now would be a good time to order moser 31 spline axels to upgrade from the OEM 31 spline , but ill wait to see if anyone has any used ones they wanna sell. thanks !
axle/backing plate bolts/ extras in my shop for free!
I have 8 of the 3/8 t bolt and nuts, and 5 of the 1/2 "d" style and 4 of the 1/2 "t" style. You can have any you want for free, send me a pm with your address and I'll send them to you. Greg blown473 I get from the forums, so I give back....
blown473- Posts : 376
Parts shipped
Got the bolts and nuts shipped out to you this morning. Tracking #0307 3330 0001 6117 5530 Don't worry about the shipping, it was only $5.65 no big. Greg blown473
» Needed: 1978 ford Bronco taillight assimblies
» PART NEEDED ASAP CAM THRUST PLATE ROLLER
» More brake questions- This is a very specific FORD part question. ---Lem and others
» 9" third member needed
» P I valves ( stock Ford) FOUND No longer needed
