Baseline tune question
511Fox
rddogoli
Re: Baseline tune question
Steve, you seem to be the guy to ask this question to, but anyone is welcome to give me feedback. When i just run 557ci 14.5:1 engine i gap my AR3933 plug at .040 and no problems at 32degree timing. If i want to hit a 150-200 shot plate what gap would be good and what timing. Thanks, Bob
rddogoli- Posts : 19
How Much?
rddogoli how much HP & TQ 'Ya making with that much CR?
511Fox- Posts : 251
rddogoli wrote:Steve, you seem to be the guy to ask this question to, but anyone is welcome to give me feedback. When i just run 557ci 14.5:1 engine i gap my AR3933 plug at .040 and no problems at 32degree timing. If i want to hit a 150-200 shot plate what gap would be good and what timing. Thanks, Bob
less.
whatbumper- Posts : 3024
rddogoli when you get a chance post as much detail of your build as possible .... cam, heads, fuel etc....
557ci, A460 ported heads/matching intake with 235/188 valves, 14.5comp. 820lift comp cam solid roller, 1150 wilson carberator worked dominator out of Memphis, BTE powerglide with NOS converter set for around 250 shot and use 116 octaine VP fuel when I can get it or 116 octaine renigade fuel. car wt. is around 3200+ with me. all components are at the highest standard forged. guess that's basically it.
rddogoli wrote:557ci, A460 ported heads/matching intake with 235/188 valves, 14.5comp. 820lift comp cam solid roller, 1150 wilson carberator worked dominator out of Memphis, BTE powerglide with NOS converter set for around 250 shot and use 116 octaine VP fuel when I can get it or 116 octaine renigade fuel. car wt. is around 3200+ with me. all components are at the highest standard forged. guess that's basically it.
Sounds like a great build Have run it yet? If so any time slips what did it run on motor? Thx.
deliveredfast- Posts : 358
I have not run this set-up yet, just had open heart surgery a month ago, got a driver for it though till I get better. hoping to run mid 5's with this set-up. ran 5.62 last season without head work and a smaller cam/carb/wrong rockers and push rods. Blew the head gaskets out on that run, now I have the cosmetic ones Cevans suggested.
Great Combo
rddogoli great combo.
Really sorry to hear about your health.
What make & year is your car
511Fox- Posts : 251
the car is a 71 maverick grabber.
ok guys and gals, now that we all know basically what i have, can someone give me some heads up on what to set the plugs and timing if i run a 175 shot on this engine? thanks so far for all the feedback, Bob
BOB,
Honestly give Steve a call at Induction-Solutions and he can give you some baseline timing and jet numbers over the phone here is his number --
815-341-8853
he will give you timing #'s , jet spread and plugs/gap to use ...... trust me give him a call
815-341-8853
will do Bruno, hope to see all you guys at the summer bash this year if my health is good. Bob
hope to see you at there this year Bob ...take care of yourself
Thanks bruno, getting with wifeeee now to see what she can do for vacation time that weekend. I have been told for some years now that if I want a good tune up it is best to have the guys see what i have, hear it and see it run. I was told at the bash I can get all the help I can want. cool. Bob
Hey rddogoli , you have a private message
paulie9fingers- Posts : 134
Howdy
rddogoli X2 on the PM.
511Fox- Posts : 251
recieved and saved, thanks for all the feedback guys, good advice and I will take all I can get. Bob
Hey Bob,
Sorry for the slow reply, but here's my thoughts..
If it were mine and with 14.5 to 1 and wanting to spray it I would go to a 3932 plug at about .025 to .030 gap.
You mentioned that last year you blew the head gasket out ??? Have you track tested your base timing to make sure it is in the best place it can be as well as the safest place for your set up ?? Hearing this alone makes we very cautious on your timing numbers..
As far as your fuel goes, I would pick one and stay with it. The couple of guys I have helped that ran Renagade didn't run it for long. Seemed we needed to run quite a bit more fuel pressure to make things happy. On a BBF with high compression I would sure take a look at VP NO2 fuel.
As for the 150-200 HP plate system ?? I'm not sure who's system you have or what size nitrous and fuel jets your calling 150-200 ??? The proper N/F ratio has a lot to do with the timing you'll need to retard as well as the results you'll get out of the set up.. We blueprint, flow and properly jet map a lot of plate systems and the results are all over the place depending on the style of plate, solenoids used, and the line sizes. Bruno found this out as his main restrictions weren't even his jets..
Hope this helps.. Steve
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
» DA Shock baseline please
» Jetting baseline for new 302 build
» small nitrous line and a bigshot plate
» what tune do I have ?
