chassis body update
+8
D. Sea
Northwest outlaw
Treeyasoon
KY JELLY
12 posters
chassis body update
Thought I would share some pics of my progress which is moving a little behind schedule.
got the car all one color now just about ready for paint pending a little fab and body work on the front cap / hood.
I added spindle mount struts and building a new tree out of chromoly tubing for the front cap. I butterflied the mounting pads and lost enough material to take the place of one pad and will only run 4 on this set up.
The strange light weight brake kit comes in at 2.2 lbs per side with brake pads and mounting brackets.
Managed to lose just a tad over 20 lbs not counting the spindle mount wheels , this should more than offset the weight of the paint and keep me out of the dog house with Lem for painting the car.
I plan to add a carbon fiber wing and then wheel tubs and floor panels down the road so I should be able to get 50-60 lbs off the car. It all adds up , Dan I am gonna need a 4 sticker to replace that 5
KY JELLY- Posts : 1530
Re: chassis body update
looks great Randy ......
That looks killer...what length and weight spring are you gonna' run?
Treeyasoon- Posts : 759
looks good Randy mine will be there soon.....
the Coug- Posts : 3055
Thanks, I run a 8" 225 lb spring on the front and 14" 85 lb on the rear
Is that car a 4-link KY?
Yes 4 link double adjustable shocks with a diagonal link. Its a mild steel chassis will weigh in around 2350# ish with driver after the diet
you must be one skinny fellow you cant live on racen alone,have a cold one low carb tho
cool40 wrote:you must be one skinny fellow you cant live on racen alone,have a cold one low carb tho
naww he's just a sawed off little f-ck...................
cool deal looking good.
Northwest outlaw- Posts : 962
Very nice Randy
D. Sea- Posts : 2768
Looks very nice!!!!!! Good luck with your build. Thanks & have a nice night!
Kevin93- Posts : 67
Going to be damn slick in paint.
Are you going to 'glass in the front tree pads or just bolt/rivit in?
DILLIGASDAVE- Posts : 2262
thanks guys.
I am going to glass them in Dave. I use screws in the pads until the fiber glass cures. It seems to hold good .
Nevs- BBF CONTRIBUTOR
got the new chromoly tree done and fiberglassed in today , it weighed in at 6.2 lbs . The way I built it I can now trim off about an 8" strip of fiberglass under the hood on the front cap all the way across the front. The mild steel tree weighed a little over 12 lbs so it was worth the effort .
Nice, me likey!
» Finally getting the Ranger body on the chassis
» 1993 mustang GT body $1000.00 / 1991 mustang GT body $500.00
» 598" ;) A head - Dyno results page 6
» chassis tuning
» Need a Chassis for my new build. GOT ONE!!!
» chassis tuning
