73 mustang parking brake cable routing
73 mustang parking brake cable routing Empty 73 mustang parking brake cable routing
Post  Maddmattmustangs April 6th 2010, 10:09 am
does anyone have a diagram or even pictures of what the brackets and cable paths look like?
Apparently the previous owner removed them Mad
Maddmattmustangs
Maddmattmustangs
73 mustang parking brake cable routing Empty Re: 73 mustang parking brake cable routing
Post  CDMBill August 16th 2010, 3:46 pm
The brackets on my 71 are stamped steel l-shaped that attach inside the rear frame rail section just ahead of the access hole for the front leaf spring bolt. They appear similar to those used on 67-70 Mustangs. The cables route through horizontal slots created by a relieved flange under the seat pan of the floor board and the reinforcements that are spot welded in this area on my convertable. Non-convertables with not likely have that extra bracing. At the front they use a 5" or so long double hooked rod on the passenger side and then another stamped bracket that attaches to the actuator cable.
I see if I can figure out how to post a picture here or look under any 67-73 Mustang.
CDMBill
Post  Maddmattmustangs September 6th 2010, 9:30 am
I could really use a picture, not many 71-73 mustangs here Sad
Maddmattmustangs
Maddmattmustangs
