472 et against a 545
johndickjr
472 et against a 545 Empty 472 et against a 545
Post  johndickjr April 7th 2010, 8:07 pm
building a 80 coupe stang, at this time im unsure on what to do, either a 545 with ported doves or a 472 with alum scj heads, with a roller around 680 lift...victor intake, 11-1 compression..3.55 gears 4000 converter etc..what kind of et am i looking at ? wanting to run at least 10.70's , but i only have enough $$$ to either buy a stroker kit or buy some alum scj heads,, i do have h-beam rods for a 460, im not scared of some rpm, with the 472...would love to have both but ...bla..bla..bla...
johndickjr
472 et against a 545 Empty Re: 472 et against a 545
Post  dfree383 April 7th 2010, 8:10 pm
Go with the heads, you'll hit your goals no problem with the 472 and SCJ's. Why waste time on a set of factory iron, with the SCJ's priced so good right now.
add the rotating assemble later when the motor needs freshened.
Post  johndickjr April 7th 2010, 8:34 pm
dfree383 wrote:Go with the heads, you'll hit your goals no problem with the 472 and SCJ's. Why waste time on a set of factory iron, with the SCJ's priced so good right now.
thats why i was thinking about the alum scj heads , cant beat that head for the $$$, looking like it will be a 472, with h-beam rods 11-1 , srp pistons, victor intake , 1050 dommie, 3.55 gears , 4k stall, looking at roller cams 680 lift area 3000-7000 rpm range maybe a tad bigger
johndickjr
Post  dfree383 April 8th 2010, 5:59 am
Little more gear and compression if it's a race car. FT's with 0 deck will get you about 11.5-11.7
Post  racerk_2000 April 8th 2010, 10:50 am
I am building a mustang along the same lines. I went with the heads first and the stroker will come later.
They are righ about the super deals avaliable on the SCJ's, get with Lem.
Keep us posted on your build.
racerk_2000
472 et against a 545 Empty Your Build
Post  511Fox April 8th 2010, 5:12 pm
Your build sounds like fun johndickjr please keep us posted. cheers sunny Very Happy
511Fox
Post  plovett April 8th 2010, 11:02 pm
Heads are the heart of your engine. Cubic inches just move the rpm range up or down. Go with the heads IMO.
paulie
plovett
Post  BOSS 429 April 9th 2010, 12:04 am
scj's
472 et against a 545 Empty My $.02
Post  511Fox April 9th 2010, 6:03 pm
SCJ X2
511Fox
