3/8 or 7/16 push rods
deliveredfast
3/8 or 7/16 push rods Empty 3/8 or 7/16 push rods
Post  deliveredfast April 13th 2010, 10:56 pm
what push rod should I use? 3/8 or 7/16 push rods. I got A460 tfs heads, 2.45 ti intake valves and 1.88 ss exhaust. Manley nex tex springs which are good to 8.50 lift. Any suggestions? thx.
deliveredfast
deliveredfast
3/8 or 7/16 push rods Empty Re: 3/8 or 7/16 push rods
Post  Curt April 13th 2010, 11:14 pm
Big and stiff affraid
Post  Lem Evans April 13th 2010, 11:17 pm
7/16 are better........gotta change the guide plates. may or may not rub the head hole or the upper lifter. If a guy wanted a tinker toy deal.....3/8" with a .135" wall is an upgrade....not as good as the 7/16 but better
Post  dfree383 April 14th 2010, 8:05 am
Lem Said what needs to be said........
Post  whatbumper April 14th 2010, 9:06 am
We run 7/16 on all our junk even the sb stuff. With as much boost and spring pressure we run it is a must.
Post  IDT-572 April 14th 2010, 3:27 pm
whatbumper wrote:We run 7/16 on all our junk even the sb stuff. With as much boost and spring pressure we run it is a must.
That's why an exhaust valve will float sometimes before a heavy intake will............. (cylinder pressure) Wink
You need 7/16 Charles.
Post  bruno April 14th 2010, 3:32 pm
not every 7/16 pushrod is made the same .... which wall thickness would you guys run ? .0800 , .120 , or .165 .......
do you pefer straight, tapered etc.....
and what material ....4130 or 4130 chromemoly etc.......
just curious
http://WWW.CKRME.COM
Post  dfree383 April 14th 2010, 4:14 pm
The bigger the push rod diameter the thinner material you can use, Lem has a real nice chart showing the strengh's of various diameter and thickness of pushrods.
Post  Lem Evans April 14th 2010, 4:32 pm
Can't run a tappered rod with guide plates. Depends on the valve spring pressures somewhat. I will say that the .125 and .165 are more desirable with power adders. A .080" 7/16" rod is better than a .135" 3/8" rod.
Post  Lem Evans April 14th 2010, 4:36 pm
3/8 or 7/16 push rods Trendperformance20001Medium
7/16 x .080 = 13,947 @ 8.00"
7/16 x .125 = 16,079 @ 8.00"
Post  deliveredfast April 14th 2010, 6:59 pm
Thx to all that replied. I'm using Jessel Shaft rockers, so no guide plates and I have the 18 bolt TFS heads so the push rod hole is already opened up. So which is better tappered or straight?
deliveredfast
deliveredfast
Post  dfree383 April 15th 2010, 8:51 am
I'd stick with the strait stuff if you have clearance, It will save a few $$.
Post  Lem Evans April 16th 2010, 7:08 pm
The "hole" in the 18 bolt stuff is longer but no wider.....it still begs to be checked.
