Jomar Stud Girdle #1145
jpb6061
68galaxie
Jomar Stud Girdle #1145 Empty Jomar Stud Girdle #1145
Post  68galaxie April 15th 2010, 1:13 pm
I am having a few issues putting my 502 back together. This time paying very close attention to the valvetrain.
I have the later A429 cylinder heads. New valves, springs, retainers, locks, guide plates and rocker studs.
Jomar stud girdle #1145.
I am fitting the rocker arms ( Crower stainless ), and noticed the Jomar stud girdle doesn't fit as well as I would have thought they would. I have attached a few pics. The 4 exhaust studs seem to line up and fit with the girdle - the angles
and separation seem OK. Now all 4 intake studs seem to be spaced correctly but at a slightly different angle (see pics)
There is a gap present. Has anyone seen this before? I can certainly tighen up the stud girdle - which would "bend" the intake studs?
Any ideas?
Jomar Stud Girdle #1145 Jomar1
Jomar Stud Girdle #1145 Jomar2
68galaxie
68galaxie
Jomar Stud Girdle #1145 Empty MIGHT HAVE AN IDEA......
Post  jpb6061 April 15th 2010, 1:41 pm
Just a thought...
What are the Serial Numbers of your heads?
There is a series of heads (roughly S/N 2000 -5000) that were machined slightly different and we make a Stud Girdle P/N 1144 to fit those heads. (Alan Root vs. Jack Roush or something like that.)
Your picture looks exactly like what we would see with the wrong bars.
give us a call at 248-322-3080 and we can discuss it.
JB
(Jomar Performance)
jpb6061
Jomar Stud Girdle #1145 Empty PS.... CHECK THE ADJUSTMENT NUTS FOR RUNOUT!!!
Post  jpb6061 April 15th 2010, 1:45 pm
Just because they don't look like Jomar parts! (and there are some copies out there with a lot of runout)
JB
jpb6061
Jomar Stud Girdle #1145 Empty Re: Jomar Stud Girdle #1145
Post  the Coug April 16th 2010, 6:18 am
Post the seriel # of your heads they have a couple different sets of girdles for them. I have a set with the clipping problems and it takes it's own girdle....
Post  curiousgeorge April 16th 2010, 8:26 am
Two words CALL THEM, but have plenty of time when you do. I had one break a adjusting nut and called to get a new set. An hour and a half later I had a new set ordered and a few more hours of checking to do, studs, rockers. They will go through everything with you to check to make sure that you have the right girdle in the end. They are some A++ guys. cheers
curiousgeorge
Post  68galaxie April 16th 2010, 9:19 am
I did give the guys at Jomar a call.
Fantastic help!!
It would be great if every company had customer service like Jomar does.
68galaxie
68galaxie
Post  83-88T-Bird Guy April 17th 2010, 11:03 am
Those guys @ Jomar are great !
They were very helpful to me when I had questions.
83-88T-Bird Guy
83-88T-Bird Guy
Post  longroofracer April 18th 2010, 12:14 am
68galaxie wrote:I did give the guys at Jomar a call.
Fantastic help!!
That is good... but what was the issue?
longroofracer
longroofracer
Post  68galaxie April 19th 2010, 6:30 pm
The issue (I think) is that I have a set of late heads that are machined like the #2000 to #5000 A429 heads.
I will find out when the 1144 stud girdle arrives - hopefully it fits.
68galaxie
68galaxie
