572 or 605?
+13
DanH
Treeyasoon
jesse
17 posters
Page 1 of 2
Page 1 of 2 • 1, 2
572 or 605?
i'm looken to go a little bigger and i know bigger is better but i have a nice bryant 4.250 crank i bought new and have in my engine now.i can go with a idt block and punch it to 4.625,use my crank & rod's=572.or buy another $$$$$ crank & rods 4.500 =605.how much would i be missen out on by going with the 572?let's say the heads would support the 605 very well also,what kinda difference in the peak hp/tq would it have and at what rpm?
Re: 572 or 605?
i would keep the crank you have
and do the 572
and do the 572
jesse- Posts : 447
Re: 572 or 605?
i'm kinda thinken
Re: 572 or 605?
if you have a nice crank so sense in buyin another one
Re: 572 or 605?
jesse wrote:i would keep the crank you have
and do the 572
no no no!!!! get other crank rods pistons, and give me that junck crank you got in there now befor it falls out and makes a mess.. J/K
keep what you have now and get pistons IMO... BUT IF
res0rli9- BBF CONTRIBUTOR
Re: 572 or 605?
would the 572 make as much power as a 605 at more rpm?
Re: 572 or 605?
Lets' just say it will make 1.65 HP/Cubic Inch.
572 X 1.65= 943.8
605 X 1.65= 998.25
572 X 1.65= 943.8
605 X 1.65= 998.25
Treeyasoon- Posts : 759
Re: 572 or 605?
question would be if 55hp is worth the $ of another crank.
Re: 572 or 605?
I'd use what you got in hand. If it don't make enough power then just spray the damn thing like Nick would ...........
TravisRice- BBF CONTRIBUTOR
Re: 572 or 605?
personally I would use what you have allready it is payed for and it will build a bunch of power.....
the Coug- Posts : 3055
Re: 572 or 605?
Depends on the cyl. heads......which are? A 572" can make 1,000 + hp....one carb. and gas.
Re: 572 or 605?
i have a460's but i'd like something better.Lem Evans wrote:Depends on the cyl. heads......which are? A 572" can make 1,000 + hp....one carb. and gas.
Re: 572 or 605?
cool40 wrote:i have a460's but i'd like something better.Lem Evans wrote:Depends on the cyl. heads......which are? A 572" can make 1,000 + hp....one carb. and gas.
I've got a new set of C heads, cnc ported by Charlie Evans, complete with rockers and titanium valves......
Nevs- BBF CONTRIBUTOR
Re: 572 or 605?
I got a new Eliminator Premier ... worked on by nobody
DanH- Posts : 1081
Re: 572 or 605?
how would your heads run on a 572 vs's a 605?Nevs wrote:cool40 wrote:i have a460's but i'd like something better.Lem Evans wrote:Depends on the cyl. heads......which are? A 572" can make 1,000 + hp....one carb. and gas.
Re: 572 or 605?
cool40 wrote:how would your heads run on a 572 vs's a 605?Nevs wrote:cool40 wrote:i have a460's but i'd like something better.Lem Evans wrote:Depends on the cyl. heads......which are? A 572" can make 1,000 + hp....one carb. and gas.
On a 4.6250" bore, they will work real well. I'd be disappointed if they didn't make way over 1100 horsepower, I figured they would go 1175 in a 605" application. I'm sure Charlie could tell you better than I.
Re: 572 or 605?
i'm thinken i'll use what i have and go 572.it'll make a lot of power and i have the crank & rods already.what kinda rpm would a 572 peak at with a good c head?
Re: 572 or 605?
Depends on cam and induction but 7000-8000 isn't out of line.
Re: 572 or 605?
So would we all...like something better. How good are the A460 units and which castings? There are better A460 deals in most cases . You said you "can" go the elim. block for the 4.625" bore.........what do you have now?cool40 wrote:i have a460's but i'd like something better.Lem Evans wrote:Depends on the cyl. heads......which are? A 572" can make 1,000 + hp....one carb. and gas.
Let's put some context to this....a 4.5" crank will be better than a 4.25"...depending on bore...what bore do you have now? What are the hp goals and budget? .......Then there can be answers.
Re: 572 or 605?
i'll soon find out how "good" my a460's are when i get them off.they're the motorsport's from way back in the 80's,i did the port work,everhow it may be,the block i have is a .080 dove.i plan to have a idt block and wanted to know how much better a 605 would be than a 572.i'd like all the hp i can get and what's a budget?Lem Evans wrote:So would we all...like something better. How good are the A460 units and which castings? There are better A460 deals in most cases . You said you "can" go the elim. block for the 4.625" bore.........what do you have now?cool40 wrote:i have a460's but i'd like something better.Lem Evans wrote:Depends on the cyl. heads......which are? A 572" can make 1,000 + hp....one carb. and gas.
Re: 572 or 605?
Bigger engine w/o better heads/manifold.carb/cam may not be very productive.
You "plan" to have big $ block. I'd "plan" to to have better stuff......1st thing is.....find out how good the stuff you have is. I.M.O.
Re: 572 or 605?
i'll see what the a460's are when i get them off cuz like you said it's good to know.what do you think about the idt 903a plus cnc'd with 2.5/1.82......on a 572? thanksLem Evans wrote:Bigger engine w/o better heads/manifold.carb/cam may not be very productive.
Re: 572 or 605?
cool40 wrote:what do you think about the idt 903a plus cnc'd with 2.5/1.82....
I think that is a very Large request! You are going to exceed the 4" rule, and make your valves kiss
Curt- Posts : 2791
Re: 572 or 605?
4 inch rule , few heads break that from the start
DanH- Posts : 1081
Re: 572 or 605?
My C's do, 4.330" combined.....2.450"X1.880".......
Page 1 of 2 • 1, 2
Page 1 of 2
