Trans pan gasket
mustang68mustangs1
Trans pan gasket Empty Trans pan gasket
Post  mustang68mustangs1 April 18th 2010, 11:19 am
How do you guys like to put a new trans gasket on without it leaking. I have a stock pan. Rubber or cork gasket.dry or some type of sealer?
Bob
mustang68mustangs1
Trans pan gasket Empty Re: Trans pan gasket
Post  whatbumper April 18th 2010, 3:29 pm
with a stock pan it is tough but I would recommend a good rubber gasket. If you use a cork gasket you can use some silicone but make sure it is almost dry before you put it together.
Post  cool40 April 18th 2010, 11:01 pm
use weatherstrip glue on both sides of the gasket and you will not have any leaks,just hope you dont want it off again. Laughing
Post  richter69 April 18th 2010, 11:56 pm
stock pan make sure its flat and the bolt holes are not pulled in, use a cork gasket............dry on both sides.....do not over torque Exclamation
Post  the Coug April 19th 2010, 8:36 am
richter69 wrote: .....do not over torque Exclamation
Jon I find this is the Problem on 99% of what goes wrong with most trans pan gaskets....
Post  whatbumper April 19th 2010, 10:48 am
I cut most of the handle off a 1/4" rachet that I found on the road. My poor mans torque wrench. Very Happy Keeps me from the over torque that I tend to do.
Post  bigblockfox468 April 19th 2010, 11:02 am
What about an aftermarket deep aluminum pan? scratch
bigblockfox468
bigblockfox468
Post  whatbumper April 19th 2010, 11:30 am
bigblockfox468 wrote:What about an aftermarket deep aluminum pan? scratch
Keeping them from leaking? Cork gaskets work fine dry. Just torque lightly and even all the way around. I don't know exact torque settings but snug is usually good. If not then you can go with a rubber gasket and torque a little more.
Post  mustang68mustangs1 April 19th 2010, 1:18 pm
Ok guys, thanks for the replies. I went ahead and did it before you guys replied. But heres how I did it. I dropped the pan, changed the filter, I bought some of the silicone made for transsmissions. Tranny fluid isnt supposed to eat it.I cleaned the pan really good. The pan was in real good shape.I put a real thin coat of the silly cone on the pan then stuck the cork gasket to it, then I put another real thin coat on the gasket. Then I put the pan with a few bolts just lightly snug,waited a few hours for the silly cone to set up then installed the rest of the bolts and just lightly torqued them with a 1/4" ratchet. We'll see what happens. I cant seem to ever istall one without leaks.
I really want to get an aftermarket pan but I needed to get this done.
Bob
mustang68mustangs1
Post  whatbumper April 19th 2010, 1:33 pm
if that doesn't work a lot of people use this.
Trans pan gasket Displa10
Post  mustang68mustangs1 April 19th 2010, 10:35 pm
mustang68mustangs1
Post  the Coug April 20th 2010, 8:01 am
I like to use studs on the trans pan also, it makes for easier alinement and never have to worry about pan gasket slippage, then I use Poly locks nuts on the studs...with a small washer.....
Post  Oldani April 23rd 2010, 9:22 pm
Farpak or Accopac gaskets are the schizzle. Put them on dry, or with a light coat of Transgel assembly lube on each side so they come apart easier. Torque pan bolts to roughly 95 in/lbs with an accurate torque wrench.
Oldani
Oldani
Post  mustang68mustangs1 May 2nd 2010, 12:51 am
Well fired up the car today and took it for a spin. Got back to the garage and its leaking on the pass. side a little. I snugged up the bolts a hair and we'll see. I'm done with this stock pan I'm ordering an aluminum one.I was looking at the Moroso fabricated alum. pan. Anyone use this or should I just get a cast pan. Do they really help.I know they help strengthen the case. Do they make it easier to keep the pan from leaking.
Seems like theres never enough time to do it right but always time to do it again. I guess I was just itchin to get the car running.
Bob
mustang68mustangs1
Post  Oldani May 2nd 2010, 7:22 am
What trans do you have? If it's a Glide I carry the fabbed Stef's pans in stock. They're a nice piece.
Trans pan gasket Stefspglidepan
Oldani
Oldani
Post  mustang68mustangs1 May 2nd 2010, 4:39 pm
Thanks Oldani. I was looking around last night and I am kind of limited to a stock depth pan which is about 2" because my exhaust runs right along side the pan on both sides. I have a c-6 and I have 3.5" exhaust. The Moroso pan is only 2" deep. Even the cast pans are all 2 Qt. extra. I would love to be able to run 2 more Qts. Is the Stef's pan deeper than stock. It looks like it is because I see the filter spacer.I even had to clearance the exhaust on the drivers side because of the shift linkage.
Those Stef's pans are a nice piece.
Bob
mustang68mustangs1
Post  Oldani May 2nd 2010, 4:59 pm
Yes, the Stef's pans are deeper.
Oldani
Oldani
Post  mustang68mustangs1 May 2nd 2010, 5:10 pm
That sucks since the Stef's are a very nice pan and looks to be cheaper than the Moroso from looking @ your site.
mustang68mustangs1
Post  Oldani May 2nd 2010, 5:21 pm
I'll double check with them and confirm the depth as I don't stock the Ford ones. Once I find out I'll post here or PM you.
Oldani
Oldani
Post  res0rli9 May 2nd 2010, 5:44 pm
Oldani wrote:I'll double check with them and confirm the depth as I don't stock the Ford ones. Once I find out I'll post here or PM you.
post here please
Post  mustang68mustangs1 May 2nd 2010, 10:45 pm
I emailed Stef's also, just waiting for a reply. If it works for me I would like to order it from you.
Bob
mustang68mustangs1
