stock ford 9 inch locker spine count.
+6
fordman460
Northwest outlaw
Maddmattmustangs
10 posters
stock ford 9 inch locker spine count. Empty stock ford 9 inch locker spine count.
Post  Maddmattmustangs April 19th 2010, 10:14 am
does anyone know what the stock spline count was for factory 9in locker rearends? i heard there all 28 spline.
Maddmattmustangs
Maddmattmustangs
stock ford 9 inch locker spine count. Empty Re: stock ford 9 inch locker spine count.
Post  Northwest outlaw April 19th 2010, 10:18 am
not 100% its been some time looking at stock stuff but i think 28,31 some one mite chime in to give you a 100% answer
Northwest outlaw
Northwest outlaw
Post  Maddmattmustangs April 19th 2010, 10:39 am
I hope so. The 8.8 i was going to use turned out to be badly cracked in the axle tubing and warped on the otherside Sad
Maddmattmustangs
Maddmattmustangs
Post  whatbumper April 19th 2010, 10:54 am
some were 31 spline but that does NOT mean they are the same strength as aftermarket 31 spline stuff.
Post  Maddmattmustangs April 19th 2010, 11:03 am
whatbumper wrote:some were 31 spline but that does NOT mean they are the same strength as aftermarket 31 spline stuff.
yea i figured as much. im back to poking around for rears and i figured why not just stuff a 9in in and be done with it. plan on swapping axles and the 3rd member housing and gears regardless on what i find.
Maddmattmustangs
Maddmattmustangs
Post  whatbumper April 19th 2010, 11:54 am
You can get some really good stuff here.
http://www.quickperformance.com/
stock ford 9 inch locker spine count. Empty Spline.
Post  fordman460 April 19th 2010, 12:53 pm
The factory Ford ones were 31 spline.
fordman460
fordman460
Post  jasonf April 19th 2010, 2:44 pm
What did Ford put a factory locker in? As far as posi and normal diffs most cars were 28 spline and the trucks were 31 spline.
Post  Maddmattmustangs April 19th 2010, 2:52 pm
lockers were installed in 71 boss and 429 scj mustangs
Maddmattmustangs
Maddmattmustangs
Post  DILLIGASDAVE April 19th 2010, 7:50 pm
"Factory" 9" Detroit Lockers were available in both 28 & 31 spline. If you want a 35 spline 9" Detroit Locker (using the "Dana 60" 35 spline 30* pressure angle profile) your only choice is the aftermarket like Mark Williams, Moser, etc, etc.
Post  res0rli9 April 19th 2010, 8:26 pm
Maddmattmustangs wrote:lockers were installed in 71 boss and 429 scj mustangs
and 68-70 cj, scj 428
Post  the Coug April 20th 2010, 7:56 am
all 9" rears were 28 splined but the 302 Boss, 351 Boss, 429 Boss, 428 CJ and SCJ, and the 427 Cars and they were 31 splined...... and some of the pickups are 31 splined also... but I have found no significant reasoning in which ones were and were not.....
Post  Maddmattmustangs April 20th 2010, 9:22 am
thanks for the reply guys. Found a 71 mach 1 locally that a friend of mines father owns. going to go check it out and see if its got a 9 in.
Coug, Im assuming that the heavier 3/4 ton trucks are probably the ones with the 31 spline?
Maddmattmustangs
Maddmattmustangs
Post  whatbumper April 20th 2010, 9:48 am
Maddmattmustangs wrote:thanks for the reply guys. Found a 71 mach 1 locally that a friend of mines father owns. going to go check it out and see if its got a 9 in.
the only trucks with 9" rears were 1/2 ton. you can find then well into the 80's. bronco's only had 28 spline axles for most of the 60's and 70's but could be both in the later build dates but like Coug said in the trucks there really is no rhyme or reason to application.
if you're concerned about big bearing housings or small bearing housings you can look at the backing plate retaining nuts for an easy reference. the big bearing housing had 1/2" bolts and small bearing housings had 3/8" bolts.
a little more fyi
Post  Maddmattmustangs April 20th 2010, 9:54 am
if you're concerned about big bearing housings or small bearing housings you can look at the lug nuts for an easy reference. the big bearing housing had half inch studs and small bearing housings had 3/8 studs.
a little more fyi
thanks. I want to try and find a big bearing housing to install on the car.
Maddmattmustangs
Maddmattmustangs
Post  fordman460 April 20th 2010, 10:11 am
a little more fyi
Lug nuts? You mean the backing plate studs don't you?
fordman460
fordman460
Post  whatbumper April 20th 2010, 10:28 am
yep. Embarassed good catch. had people talking to me when I typed.
backing plate bolts is what I was thinking. the small bearig housings use a 9/16" wrench and the big bearing housings use a 3/4" wrench.
I fixed it above too.
Post  Maddmattmustangs April 20th 2010, 10:30 am
alright sounds good!
looks like i need to bring a few wrenches to the junkyards Very Happy
Maddmattmustangs
Maddmattmustangs
Post  whatbumper April 20th 2010, 10:32 am
I got in a hurry typing earlier. please make sure to check the backing plate bolts. I wasn't really thinking axles when I typed that above, i was thinking a bare case. I fixed it above. Thanks fordman460! Very Happy
Post  Maddmattmustangs April 20th 2010, 10:55 am
will do. hopefully ill be back in the junks digging for parts wednesday Smile
Maddmattmustangs
Maddmattmustangs
Post  bosshoss April 20th 2010, 12:42 pm
Not all big bearing ends have 1/2 bolts. I have seen just as many with 3/8 as well. Then of course there is the weired Torino big bearing end with 3/8 bolts and a different bolt pattern? Never could figure out the sense in that one but they are out ther none the less. I would be looking at the size of the tubing at the outside end of the housing. The small bearing ones will be smaller. The big ones will be 3" at least right out to the bearing.
dkp
bosshoss
bosshoss
Post  DILLIGASDAVE April 20th 2010, 10:35 pm
bosshoss wrote:Not all big bearing ends have 1/2 bolts. I have seen just as many with 3/8 as well. Then of course there is the weired Torino big bearing end with 3/8 bolts and a different bolt pattern? Never could figure out the sense in that one but they are out ther none the less. I would be looking at the size of the tubing at the outside end of the housing. The small bearing ones will be smaller. The big ones will be 3" at least right out to the bearing.
dkp
This is true, there are two 3.150" "big bearing" housing ends. One has small bolts & the other big bolts.
And not all big bearing axles had the common closed/sealed ball bearing, some had the PITA tapered axle bearings that when the bearing fuuked up/burned-up & came apart the tapered bearing outer race would weld it's self to the inside of the housing end. Mad
Post  duff429 April 21st 2010, 2:39 am
i have a factory locker rear end. 31 spline. also you can tell if its 31 spline if the stud flange has "1" big hole vs 2 like 28 spline. dont get truck axles or you will have to get new rims . also i think its anything with a 351 or bigger has a 9 inch. for the torinos
stock ford 9 inch locker spine count. 231
duff429
duff429
Post  whatbumper April 21st 2010, 9:37 am
Good info duff429.
