What tire pressures do you guys run
+11
D. Sea
4thHorseman
BIGDOG466
Barney
Treeyasoon
hayhauler
mustangjeff
15 posters
The tires are m/t et drag 14x32 with tubes & I think I am running them a little to low on pressure, I am running about 7psi.
mustangjeff- Posts : 87
Re: What tire pressures do you guys run
i run 28x10.5 between 10 and 13 psi
hayhauler- BBF CONTRIBUTOR
My 12.2x 31.5 Pheonix tires like 8#'s , the M/T 10.5 W's like 9.5.
I'd think a big tire would want 5.5-7.5, but it depends on the sidewall, weight, and set up etc.
A good pic from the starting line as the car leaves is worth a lot, that and the wear pattern on the tires can be a good indicator also.
I run the same tire....blow them up to about 9# and try it.mustangjeff wrote:The tires are m/t et drag 14x32 with tubes & I think I am running them a little to low on pressure, I am running about 7psi.
The more pressure you can run consistantly, the better.
Treeyasoon- Posts : 759
28 x 10 w/ stiff side wall -- no tubes -- 9.75lbs @ 3200lbs
15x33 m/t 5-7.the more psi you can run the better it'll act at the far end.
I think when we ran big tires we ran like 8-9psi but it was a light car. we run 13-15, depending on track conditions, now on our 29.5x10.5 tires. with our 28x10.5s tires with 10 psi our bead locks would hit the ground on launch.
whatbumper- Posts : 3024
Thanks for all the replies, i will try about 8psi to start.
It all depends on how hard the car hits the tires. My goal is to have as few ringles as possible and still hook. Also shocks can let you run more or less air. I think I got mine purdy close
BIGDOG466- Posts : 265
28x10.5 M/T ET Drag currently on a 15x10 rim tubeless. 13psi warm seems to be the ticket.
4thHorseman- Posts : 400
31 X 14 Hoosiers at 8.5psi
D. Sea- Posts : 2768
10.5 psi @3000lbs. 60 ft goes all to hell if I go higher than that.
BB94STANG- Posts : 249
3080lb 87 LX with me in it. MT 28x10.5 regular wall with tubes, 15x8 rim, Car 60fts at 1.39-1.40 with 13.75 to 14 lbs of air. Sounds like lot but the tires wear even and I started at 10psi and worked my way up and each time the 60ft numbers got better till I got past 14psi.
514Fox87- Posts : 436
I run 28x10.5 MT on a 15x8 rim w/ tubes around 10.5 lbs of air. (+/- .5 lb)
Justin
Justin
jcoxracing- Posts : 282
Bruno have you tried more pressure than that ? or does it lose traction going over 9.75 ?bruno wrote:28 x 10 w/ stiff side wall -- no tubes -- 9.75lbs @ 3200lbs
nuclearcobra- BBF CONTRIBUTOR
Same here Melvyn once i got to 14psi it hooked the best and they wear even.514Fox87 wrote:3080lb 87 LX with me in it. MT 28x10.5 regular wall with tubes, 15x8 rim, Car 60fts at 1.39-1.40 with 13.75 to 14 lbs of air. Sounds like lot but the tires wear even and I started at 10psi and worked my way up and each time the 60ft numbers got better till I got past 14psi.
» For Nick and the 10.5 tire guys
» $10k race for you 10" tire guys!!!
» New Small Tire Class. You guys aren't going to believe it.
» tire size back half frame kits tire width on 70 mustang
» 275 tires
» 275 tires
