70 mustang 9 inch into a 73 mustang body
70 mustang 9 inch into a 73 mustang body Empty 70 mustang 9 inch into a 73 mustang body
Post  Maddmattmustangs April 23rd 2010, 12:10 pm
does anybody know if the 70 mustang 9in would be a direct bolt in for my 73? I know there slightly narrower and thats fine (more room for tires Laughing ) I was just wondering if the spring pearches were the same distance apart?
Seeing as how my 8.8 is toast im trying to consider my options Mad Mad Mad Mad Mad pale
Maddmattmustangs
Maddmattmustangs
70 mustang 9 inch into a 73 mustang body Empty Re: 70 mustang 9 inch into a 73 mustang body
Post  whatbumper April 23rd 2010, 1:16 pm
I'm pretty sure that they are both right at 43 inches so you should be fine. I can't remember exactly but 43" seems right. Maybe others will chime in.
Post  jbozzelle April 24th 2010, 12:17 am
You should be Ok with the perch width. If you have both handy just measure them...
Post  David Cole April 24th 2010, 10:46 pm
Yes it will fit. The 73 is 2" wider. 1" on each side, but the spring perches are in the same location. I did the same swap in the opposite direction. Put a 73 rear in a 69 Mustang. I also went with a set of wheels that had an extra inch of backspacing that put the tires back in the same location as the narrower 69 rear.
Post  Maddmattmustangs April 26th 2010, 12:44 am
David Cole wrote:Yes it will fit. The 73 is 2" wider. 1" on each side, but the spring perches are in the same location. I did the same swap in the opposite direction. Put a 73 rear in a 69 Mustang. I also went with a set of wheels that had an extra inch of backspacing that put the tires back in the same location as the narrower 69 rear.
thats good to hear. I was hoping its would be a bolt in deal. Kinda cheating a bit and getting a rearend thats narrowed an 2 inches but bolts right in Very Happy
Maddmattmustangs
Maddmattmustangs
