Roller Lifters.......
jones
Starting to work on my next motor and I'm considering keyway lifters (Still Recovering from the Prices.... I've seen so far) Any Opinions? Looking to get into the 1.00" Lift Range but not sure of the most effective, cost effective and reasonably reliable way to get their........Hummmmmm????
1) Advantages?
2) Disadvantages?
3) Other options? Types?
4) Why 1.00" Lift? Is it worth the gains? How much is their to gain?
1) Advantages?
2) Disadvantages?
Re: Roller Lifters.......
seems like a very high maintence engine ........ whats the application ?
i saw were you were inquiring about the cnc intake from Berry Motorsports ..... you gonna run efi ? turbo/blower ?
Yes, its the motor I was asking about the intake for.
Haven't decided on heads yet, maybe C's, Profilers, Thors or ???.
Probably 598" and 2x4 dominators.
I would say "subscribed", but this site won't send me notifications (hint hint, Nick )
windsor- Posts : 1167
I told myself I would just watch this thread and not ask questions, but I have to ask.
Is the keyway oil pressure fed, bronze bushings, aluminum block only??? I would think you would be gaining some valvetrain weight and friction just for the increase in size and durability to run tombstone camshafts over 1.00 lift and 1,200lb+ springs. Is this correct?
jones- Posts : 2230
No keyway stuff can be used in Iron Blocks also, Only down side I see so far is Very Expensive. and you dont necessarily need springs in the 1200# range a 1" of lift either, alot depends on valvetrain design, geometry and desired RPM.
Lem made an interesting statment to me on the phone the other day when he questioned the old way of gaining rpm by putting bigger springs and not paying attention to the complete package. Sometimes just putting in bigger springs only covers up the real problems of unstable rockers, pushrods and poorly designed lobes or can actually make it worse.
Biggest thing you gain going to the keyway stuff from what I have gathered so far is and Increase in wheel and bearing size, which in turn makes the lifter more durable at Crazy Ramp speeds and bigger spring pressures.
dfree383 wrote:No keyway stuff can be used in Iron Blocks also, Only down side I see so far is Very Expensive. and you dont necessarily need springs in the 1200# range a 1" of lift either, alot depends on valvetrain design, geometry and desired RPM.
That's all very true...
Is thier a reason (?? Side Loading,scuffing???) Why they do not offer a bigger wheel in the smaller diameter lifters (Like .850 wheel in a .875 body lifter?) to make things a little easier on builders?
Why do you need to go to a .937 or 1.062 body to get a .850 dia Wheel?
It would seem to me with a 460 for having a decent sized cam core, thier would be a large market for better lifters at a reasonable cost??
The lifter bore is only that diameter across the middle ... it is smaller where the edges of the roller goes through.
The larger roller measurement from cross edges are the diameter which matters not their actual diameter.
dfree383 wrote:Starting to work on my next motor and I'm considering keyway lifters (Still Recovering from the Prices.... I've seen so far) Any Opinions? Looking to get into the 1.00" Lift Range but not sure of the most effective, cost effective and reasonably reliable way to get their........Hummmmmm????
1) Advantages?
2) Disadvantages?
1) yes, 1 ADVANTAGE is able to line up pushrods ,better angle
2) cost
4) not sure what head you are going to use, but we have been going over 1. for a few years,not with keyway lifters,just comp cams
-RICH
BOSS 429- Posts : 2372
i see keyway stuff in iron blocks , quite a few really a few dove blocks,2 boss 429 s
Rich,
Are You getting the Lift at the Lobe or Rocker Ratio?
What kind of life are you getting out of your lifters and what sizes are you using?
Are your lifter bores strait of offset? Bushed?
Dave
Dave
[quote="dfree383"]Rich,
WELL WITH WHAT WE DONT LOOSE WITH PUSHROD FLEX ,@ RETAINER,LOL,AND WE UP THE RATIO
STOCK SIZE, I HAVE RAN SOME FOR 10 YEARS,AND IN 5 OR 6 DIFF ENGINES,ON 5 OR MORE DIFF CAMS
Are your lifter bores strait of offset? Bushed? , STRAIGHT, WE HAVE NEVER BUSHED THEM,I HAVE GUYS WHO HAVE,AND I JUST WORKED ON ONE THAT SHOULD BE,WHY? BECAUSE SOMEONE OVER CUT THE OIL HOLE IN LIFTER
OFFSET, HERES SOMETHING I JUST DONT HAVE ALL THE TIME TO TALK ABOUT RIGHT NOW, THERES A ENGINE ON THE STAND,LIFTER VALLEY ALL WELDED UP,CHANGED OFF SET TO ALLOW FOR BETTER ANGLE,AND 60MM CAM, WE'LL TALK ABOUT THAT ANOTHER TIME
-RICH
-RICH
Care to share any pics of the modified lifter valley?
They also allow larger pushrods. The larger 1/2-9/16 pushrods can contact the cross bars.
Outlaw5.0- Posts : 122
Dave,
Once you step up to the Mopar size lifter (.903"), you are able to go from the .750" roller to the .800" roller, which helps.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
Yep, I'd agree the mopar size stuff would be an improvement.
Are their any simple formulas to calculate what effect side loading a lifter has? Hp impact? I understand its best is to have everything lined up, but wheres the breaking point to cost / maintence / reliability.
The million $$$ question.......
Install a larger Diameter Conventionaly located Link Bar Lifter and deal with the side loading and maintence on the Valvetrain / Reduced RPM potential and reliability.
or
Spend the Big $$$ and Relocate the lifter bores, use keyway lifters, and 60mm cam core..........
Hummmmm.......
or
Hummmmm.......
Outlaw5.0 wrote:They also allow larger pushrods. The larger 1/2-9/16 pushrods can contact the cross bars.
WE USE A DOUBLE TAPPER TO KEEP THIS FROM HAPPENING
YES CAPS STUCK AGAIN
» Using Hydraulic roller lifters on the Comp XR292 R-10 Xtreme Energy Solid Roller cam?
» C460 Pistons+roller lifters and roller cams...
» hydraulic roller cam with solid roller lifters
» JT557 HERE NEED SOLID ROLLER LIFTERS FOR ROLLER CAM
» roller lifters
» roller lifters
