This sucks!!!!
This sucks!!!! Empty This sucks!!!!
Post  chuck April 29th 2010, 10:02 pm
Fired the car today & you can hear a howling noise coming from the glide, could this be the pump? The noise is louder inside the car.
chuck
This sucks!!!! Empty Re: This sucks!!!!
Post  richter69 April 29th 2010, 10:41 pm
does it have straight cut gears?
And does it still do it when put in gear?
Post  chuck April 29th 2010, 11:06 pm
It's alittle bit of a binding sound,slight vibration. not streight cuts. I'm at a loss Mad
chuck
Post  Oldani April 29th 2010, 11:29 pm
What did you have for converter clearance? Needs to be 1/8" min to 3/16" max. Measure by pushing converter back into pump and then see distance from mount pads to plate. Any less and it pushes the drive gear into the stator half of the pump and eats it alive. Any more lets the drive gear ride up on the converter neck and you can also cause it to push back into the stator half or tear up the pump gear drive tangs.
Oldani
Oldani
Post  whatbumper April 29th 2010, 11:47 pm
Oldani wrote:What did you have for converter clearance? Needs to be 1/8" min to 3/16" max. Measure by pushing converter back into pump and then see distance from mount pads to plate. Any less and it pushes the drive gear into the stator half of the pump and eats it alive. Any more lets the drive gear ride up on the converter neck and you can also cause it to push back into the stator half or tear up the pump gear drive tangs.
x2 check this.
Post  chuck April 30th 2010, 6:06 am
It pulled out 3/16 with a micro, the adapter bushing is really tight on the pilot.
chuck
