alky guru's inside
alky guru's inside Empty alky guru's inside
Post  bruno May 2nd 2010, 9:28 am
so im thinking about picking up an alky 950 hp from Freelander ...... will a holley black and a standard reg work w/ alky / or will i need to buy a new pump ?
http://WWW.CKRME.COM
alky guru's inside Empty Re: alky guru's inside
Post  richter69 May 2nd 2010, 10:36 am
The black pump is compatable, the little holley deadhead regulator not so much. You really need a decent bypass style reg to make that small pump work anyway, the reg needs to anodized and the diaphram alky compatable.
Post  bruno May 2nd 2010, 10:41 am
do you have a part # Jon ?
Post  richter69 May 2nd 2010, 10:52 am
The ones we use are for belt pumps, a local machine shop that does a lot of lot of roundy round stuff gets them made. Not sure how they would work with an electric pump.
With our electric stuff we used a deadhead reg made by magnafuel, but with that small of a pump it might hurt the flow, but a good reg might not so much...........but the good ones are $$$$$$ lol.
Just make sure any aluminum is anodized or it will powder up and clog stuff up. Make sure the fuel filter is a stainless screen type.
Post  bruno May 2nd 2010, 10:55 am
sounds like it might just be cheaper to go gas
Post  longroofracer May 2nd 2010, 11:08 am
bruno wrote:sounds like it might just be cheaper to go gas
I have been comparing fuel system components... and the overall cost for alky compatible stuff isn't that much different. The difference one will notice more is quality and buying the larger size needed, as the volume the alky uses seems to me that you need to step everything up a size. In the end, the alky will save you a bit of cash when buying fuel... it's a pay me now or pay me later deal.
longroofracer
longroofracer
Post  richter69 May 2nd 2010, 11:12 am
If you buying it all new its pretty much the same coin, you can get by with a system thats not "fine tuned" on gas, alky not so much. The black pump should be fine for that sbc deal, you need a decent regulator......not sure if the big port holley deadhead deal is anodized, but i think it might work, cell in the front will be better. If you had a larger pump it would make things easier lol.
Alky is worth it, for a bracket racer the consistancy and less cooling issues are a big plus.
I dont even run a radiator in my deal, I had to hot lap it a couple weeks ago and had to run the fan on the tranny cooler and plug the block heaters in lol.
Post  longroofracer May 2nd 2010, 11:15 am
Bruno, I am guessing this is for the other car? Is the regulator you have on the mustang alky compatible? If so, you might consider using the same style regulator for the second car, which gives you sort of a backup/spare, at least until you actually start racing them both.
longroofracer
longroofracer
Post  Larry Williams May 2nd 2010, 11:51 am
bruno wrote:so im thinking about picking up an alky 950 hp from Freelander ...... will a holley black and a standard reg work w/ alky / or will i need to buy a new pump ?
I am using an alky QFT 950 on my small block I think I could go with a 1050 alky carb
Larry Williams
Larry Williams
Post  bruno May 2nd 2010, 12:02 pm
humm ... ive seen lots of guys use the standard holley reg w/ alky ... and these guys are your reg bracket warriors .....
the regs on the mustang are the standard reg ....
im just trying to use my buddies money wisely Wink
Post  KY JELLY May 2nd 2010, 12:51 pm
Nick I got a quick fuel regulator I can send you to see if it will work with the pump set up you are using. It uses a holley jet to set the idle pressure and an adjustable diaphragm for the wide open pressure. If it don't work you can send it back to me or buy it or have Lem or Phillip send you one from quick fuel if it works correctly.
KY JELLY
KY JELLY
Post  bruno May 2nd 2010, 1:45 pm
thxs Randy
Post  richter69 May 2nd 2010, 3:42 pm
KY JELLY wrote:Nick I got a quick fuel regulator I can send you to see if it will work with the pump set up you are using. It uses a holley jet to set the idle pressure and an adjustable diaphragm for the wide open pressure. If it don't work you can send it back to me or buy it or have Lem or Phillip send you one from quick fuel if it works correctly.
sounds similar to the one we use, I'd plug the bleed hole, its designed for a belt pump so it will bleed off at low rpm.............3-4 psi and when rpm comes up so does the pressure. With the electric pump the flow is constant.
