Alky belt driven fuel pump
Alky belt driven fuel pump Empty Alky belt driven fuel pump
Post  jones May 3rd 2010, 2:34 pm
If I was going to run a carburated alky setup who are some suggested belt driven fuel pumps? I know Aeromotive makes a pump and Ron's fuel injection.
PS. do you have to run a belt driven pump with an alky carb?
jones
Alky belt driven fuel pump Empty Re: Alky belt driven fuel pump
Post  richter69 May 3rd 2010, 3:07 pm
you can run electric, but they are not reliable IMO.................pumps wear out fast and not the ideal way to control the pressure the carb likes. I have only dealt with the Ron's stuff.........cell really needs to be in front but with a carb setup rear cell should be ok.
Post  whatbumper May 3rd 2010, 3:16 pm
Even though I don't run an alky setup or a carb I do run a belt drive pump (it's actually mounted on the rear of my peterson oil pump). I have an aeromotive pump with a cell mounted in the rear and it works great. LARGE feed and return lines are needed because that pump moves a lot of fuel.
Post  jones May 3rd 2010, 3:56 pm
I have an extra 3gal fuel cell I was going to mount up front if I go this route.
jones
Post  KY JELLY May 3rd 2010, 7:13 pm
I have a hillborn pump I would let go of that I was running with my carb set up. Its the best way to go you also free up your battery usage a bit.
KY JELLY
KY JELLY
Post  whatbumper May 3rd 2010, 10:43 pm
KY JELLY wrote:I have a hillborn pump I would let go of that I was running with my carb set up. Its the best way to go you also free up your battery usage a bit.
That's why we switched. Weldon 2345's use a ton of juice and that's what we had before.
Post  jones May 4th 2010, 4:44 pm
Well, let's see if we can't make a deal!
jones
