79 Ford 4x4 Truck Headers
79 Ford 4x4 Truck Headers Empty 79 Ford 4x4 Truck Headers
Post  ROAD RAGE May 7th 2010, 11:22 am
Looking for a set, new/used, for 79 f-250 4x4 4-speed, 2-1/8 tubes Coated, for fender well exit. Cobra Jet Heads.
Or if they have to be custom, A possible link.
Thanks Ed...........
ROAD RAGE
ROAD RAGE
79 Ford 4x4 Truck Headers Empty Re: 79 Ford 4x4 Truck Headers
Post  lghting94 May 7th 2010, 1:40 pm
Maddog makes a 2 inch primary header aswell as hedman(they look identical) for 2 and 1/8 or larger you can order a weldup kit from stahl and then send them off to be coated once fabricated with these kits you will have to modify your steering rod from column to box most likely. The other option is a cutom built set which the Fab Shop could help you with if you take them your truck.
lghting94
lghting94
79 Ford 4x4 Truck Headers Empty 4 X 4 Headers
Post  514Comet May 18th 2010, 4:57 pm
Have you tried L&L ? 972-475-5202. Also, LMC Truck? 1-800-562-8782. Good luck!
514Comet
Post  schmitty May 19th 2010, 9:44 am
514Comet wrote:Have you tried L&L ? 972-475-5202. Also, LMC Truck? 1-800-562-8782. Good luck!
L&L only mkes 1 7/8" for the early trucks. LMC is just standard small tube stuff too.
I would get with Tim at the Fab Shop and get a box of stuff from him. Another good idea would be to get Uncle Charlie's BBF to BBC adapter flanges. It will make it a lot easier to get the larger tubes into the flanges and be able to get at the bolts. I'm working on a set of upright headers with 2 1/8" pipe now and the Ford exhaust pattern would be tough deal. Cool
