how fast did you go with DOVE,C9VE,OR C9VE HEADS?
+7
Big block fox 339
342g
nuclearcobra
KY JELLY
Maddmattmustangs
11 posters
how fast did you go with DOVE,C9VE,OR C9VE HEADS? Empty how fast did you go with DOVE,C9VE,OR C9VE HEADS?
Post  BOSS 429 May 8th 2010, 9:53 pm
just like the title says DOVE,C8VE OR C9VE HEAD, im just wondering how quick anyones been N.A. @ 2900/3200lbs? no power adders .
how big is the engine? and @ what weight
1/4 MILE OR 1/8
thanks-RICH
how fast did you go with DOVE,C9VE,OR C9VE HEADS? Empty Re: how fast did you go with DOVE,C9VE,OR C9VE HEADS?
Post  Maddmattmustangs May 8th 2010, 11:14 pm
I personally havent BUT one of the best engine builders in the area has had a C9 headed ford push high 9's N/A in a 2900lb ish car. Wish i knew how he did it Shocked
Maddmattmustangs
Maddmattmustangs
Post  KY JELLY May 9th 2010, 12:00 am
my old 70 mustang went 6.21 1/8 with a 466 and dove c heads 2840lbs
KY JELLY
KY JELLY
Post  IDT-572 May 9th 2010, 12:02 am
6.30 514 D2ve's 3200 lb.
Post  nuclearcobra May 9th 2010, 8:49 am
I've been 10.57 @ 128.68 mph with a 1.48 60' at 2740 lbs in a 84 fox hatch its a 472'' with ported c8's with 2.19-1.72 valves and worn out single springs #926 for a 280 cam and the portmatch is way off with the 4150 victor intake,carb is a aed hp 950 i built from scratch with proform blocks and base plate with 76-86 jets the cam is a 292 comp flat hyd 244@.050-560 lift,trw 2404 pistons,c6 trans no brake and a tci 11'' converter that i cant footbrake over 1500 rpm.
nuclearcobra
nuclearcobra
Post  342g May 9th 2010, 10:38 am
6.11, 1/8th, 9.65 1/4, d-3ve-a2a heads, 2900 lb. cougar, grrrrrrrrrrr. Laughing
342g
342g
Post  BOSS 429 May 9th 2010, 12:41 pm
wow these are all supper kool guys keep em comming
-rich
Post  342g May 9th 2010, 12:45 pm
By the way, those heads are in need of a new home, very cheap, all they will need is a valve job, everything else is done.
342g
342g
Post  BOSS 429 May 9th 2010, 5:55 pm
I've messed with dove( c8,c9 ) a lot over the years ( bought my first pair in 1977) trying a lot of my own ideas and such, and was just wondering what some of your results were.
I have used them on 429s to 512ci engines ,just seing what you guys are doing
-thanks
Post  Big block fox 339 May 9th 2010, 7:43 pm
91 fox hatch full interior. Not sure of weight it's my first car still learnin to drive it I've only made about 10 passes
545 ci
234@ 50 hyd ft cam
doves very Lil port work if any 2.25 1.75 valves
10.8 to 1 cr on e85
950 carb
on 275 mt drag radials
Still ain't hooking but it went 7.08 @ 98 1/8
Big block fox 339
Big block fox 339
Post  BOSS 429 May 9th 2010, 7:50 pm
what size carb? gear?
Post  Big block fox 339 May 9th 2010, 8:04 pm
950 qft e85 out of the box
3:73 gear shifting at 5800
Big block fox 339
Big block fox 339
Post  BOSS 429 May 10th 2010, 11:15 pm
sounds like fun
Post  Race Ready Fabrications May 24th 2010, 6:18 am
My car with DOVE-C's has been a best so far of 6.201 @ 110.9mph. Its a 501, 14:1 cr, comp solid roller, victor intake and a 1050. Car weighs 3180 with me in it. I think with a cam change it will go faster. Motor has no low end and doesnt start really running until about a hundred foot out.
Post  342g May 24th 2010, 8:34 am
I just went a 6.03, 117m.p.h. at the bash, there is more in it, it was the first time out with the build. Evil or Very Mad
342g
342g
Post  56Tbird May 24th 2010, 8:39 am
My Mustang went 6.24 at 110MPH .The engine is a 472 flat top with DOVE-C heads and a roller. 4.86 gear with a 32" tire at 3045lbs. The engine went 6.00 at 115MPH in my Thunderbird
56Tbird
56Tbird
Post  bbf-falcon May 24th 2010, 8:49 am
My old Maverick went 6.24 one cool nite. Same crank/rods/pistons thats in Harolds engine now on gas and C6 at #2970 w/DoveC's and TOO much timing.
Post  k.pascoe May 24th 2010, 3:42 pm
My DOVE's went 10.50@125 1.36 60 foot 4000 lbs. 514 ci. Then they were put on a 2650 lbs. pro tube chassis car 552 ci. 8.73 @ 156 n/a and 7.83@183 with a fogger.
k.pascoe
