528 CI A Head-TFS intake,Charlie,anybody
528 CI A Head-TFS intake,Charlie,anybody Empty 528 CI A Head-TFS intake,Charlie,anybody
Post  Snowball Racing May 10th 2010, 2:16 pm
I am putting together an OLD motorsport A head, TFS intake 528 ci. cherry
I am calling it the recycled motor because I am using parts on my shelf, left from various shctuff. cheers
cam is comp .761-.761 280* @ .050 intake
296* @ .050 exhaust
Because I've never had a TFS intake, Question is, what should I do to intake other than a gasket match? How high a spacer? I have a 1" Wilson in stock.
Cam thoughts? LEM? I think it will be ok, but I'd like to hear from outside. I'm thinking 1.8 rockers on intake, and 1.73 exhaust. study
Snowball Racing
Snowball Racing
528 CI A Head-TFS intake,Charlie,anybody Empty Re: 528 CI A Head-TFS intake,Charlie,anybody
Post  dfree383 May 10th 2010, 2:24 pm
Jomar Tapered Spacer and an Extra 1" Open for starters.
Post  c.evans May 10th 2010, 5:29 pm
Robert,
If it is the old style intake, which was more of a low riser, then yes we found a total of 2" of spacers worked best. You can have a four hole into cloverleaf setting on top of a completely open spacer. I don't know what style your Wilson piece, but it an another spacer should work okay.
I'll leave the cam specs up to Lem, that's his department.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Snowball Racing May 10th 2010, 5:44 pm
NEW TFS intake, OLD motorsort heads version #1
Snowball Racing
Snowball Racing
Post  Lem Evans May 10th 2010, 7:05 pm
Comp ratio....flow # for the head.....what does the car wt. ? Glide or 5 spd. manual?
Post  Lem Evans May 10th 2010, 7:09 pm
The Jomar 1" power cone is prefered......I'm sure the 1" Wison will be good if you have one in hand and paid for Smile
Post  Snowball Racing May 11th 2010, 8:15 am
Lem,
I don't have any flow #'s . these heads went 7.78 @ 172 on a 509 short in my dragster. I think they work pretty good.
it is going in a 2600lb with driver door car with a glide.
I am going to try and put compression at 14.7
Wilson spacer is on hand and paid for... pirat cheers
Snowball Racing
Snowball Racing
Post  dfree383 May 11th 2010, 8:52 am
Flow Dem Heads !!!! Laughing
Post  Lem Evans May 11th 2010, 9:45 am
Yep, put the 1,8 on the intakes.
Post  BigBlockFalcon May 11th 2010, 7:35 pm
The spacer is a Wilson tapered spacer. Also should we leave the cloverleaf alone on the intake?
http://www.fquick.com/BigBlockFalcon
Post  Lem Evans May 11th 2010, 7:43 pm
the 'leaf' thing can go i.m.o.
Post  c.evans May 11th 2010, 11:08 pm
IMO do what you gotta' do,,,,, in order for the exit surface of the Wilson spacer, to mate/match the inlet surface of the manifold's carb pad. You can go either cloverleaf to cloverleaf, or cloverleaf to open, or open to open.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
