ProComp ignition parts?
+6
fatal addiction
Cyclone70
10 posters
ProComp ignition parts? Empty ProComp ignition parts?
Post  Cyclone70 May 13th 2010, 8:11 am
Are those procomp distributors, ignition moodules and coils etc. crap or usable?
Cyclone70
ProComp ignition parts? Empty Re: ProComp ignition parts?
Post  richter69 May 13th 2010, 8:22 am
ProComp ignition parts? Dog_cupcake_tease
Post  the Coug May 13th 2010, 8:34 am
you get what you pay for..... if it is all you an afford so be it... take a chance....
Post  dfree383 May 13th 2010, 2:16 pm
Spend the extra $$ on the MSD or Mallory stuff. Good rule of thumb with procomp parts is, if it moves or inolves electricity, avoid it........... and if it doesn't move or involve eletricity, check it over twice and still think twice about spending your money on it, because cheap usualy means more expensive in the long run......
Post  fatal addiction May 13th 2010, 2:29 pm
just go with msd and be done with it.
fatal addiction
fatal addiction
Post  maverick May 13th 2010, 7:12 pm
The only ProComp ignition box and distributor I have actually seen in operation....were nothing but grief for their owner. Maybe you'll get a good one though. Rolling Eyes
Post  '65 T-BOLT May 13th 2010, 9:51 pm
and in the magazine on the BBF build up
'65 T-BOLT
'65 T-BOLT
Post  kjett May 13th 2010, 10:41 pm
I'll say this about the pro-crap stuff. Run, run very fast away from it! I put together a basically stock 460 for my buddy's bronco and he's been having problems with the thing. When I had the motor with my MSD stuff, it had no problems, now with his procrap HEI, it's timed right at idle and runs fine, but just cruizing around it overheats and runs like crap. Putting the timing light on and revving the motor you can see the spark move all over the place and not advance as it should. Evil or Very Mad
kjett
kjett
Post  Cyclone70 May 14th 2010, 12:58 am
KO for procomp...that was what i except.
Next question would be
Mallory or MSD?
Cyclone70
Post  dfree383 May 14th 2010, 3:02 am
Msd is my first choice. Their is another company called ICE that has some decent looking stuff also.
Post  ants84olds May 15th 2010, 6:56 pm
The truck i bought has a procomp coil, ignition box, and distributor. The distributor is a billet knock off. I plan to change that out imediatley because you can see the distributor move around like the gear is not centered or its too long and binding up. Everything works it has spark and the motor runs pretty good but you get what you pay for. Im going to swap out the distributor for a stock one that i have and plan on swapping out the box and coil when money permits. All of the parts look really cheaply made and are junk im my opinion.
ants84olds
Post  Curt May 15th 2010, 7:18 pm
Run Forest, RUN!
ProComp ignition parts? Brb
