swapping heavy duty truck trans
I have a 83 Ford Fleetwood Motorhome 460/c6 with a problem trans. I found an '88 F350 460 with an overdrive c6 . I like the upgrade but will it just bolt in ?
mugzilla- Posts : 26
Re: swapping heavy duty truck trans
Nothing just bolts in.....to many Varibles
the Coug- Posts : 3055
Greg P did a swap in his Torino, I don't think it was to difficult other than cutting up the trans tunnel as the OD trans is very large, but that maynot be a big deal in a motor home.
dfree383 wrote:Greg P did a swap in his Torino, I don't think it was to difficult other than cutting up the trans tunnel as the OD trans is very large, but that maynot be a big deal in a motor home.
There IS lots of space ...
Probably just a drive shaft shortening, yoke, trans mount, harness/ computer to control the trans, flex plate change? And adapting shift linkage. Should require anything super hard, do a search on gregs installation.
» clutch fan vs regular
» Cracked C6 flexplate
» ATI Heavy duty steel flex plate.
» E4OD heavy duty towing torque converter for gas engines
» 1997 Ford F250 XLT Supercab Heavy Duty 460/E4OD ***SOLD***
