Anti-roll/Coil over ?s
Anti-roll/Coil over ?s Empty Anti-roll/Coil over ?s
Post  Jeremiah May 19th 2010, 6:45 pm
I have a foxbody coupe mustang. The car leaves pretty straight but it does squat a little harder on the pass. rear then it does on the drivers.. Can I just adjust the coil over up some or will I have to reset my anti-roll?
Jeremiah
Anti-roll/Coil over ?s Empty Re: Anti-roll/Coil over ?s
Post  Northwest outlaw May 19th 2010, 7:07 pm
Well if you have a anti roll bar is should do it I would look to see if you have a bent arm.
Northwest outlaw
Northwest outlaw
Post  DILLIGASDAVE May 19th 2010, 7:11 pm
Are you sure the body roll isn't caused from using too little air pressure in the slicks allowing the torque loading to over wind & collapse the pas side sidewall? If there is no slack in your anti-roll then cranking up one coil over shouldn't really have any effect since the anti-roll is supposed to even everything out.
If I remember correctly Damon had some body roll over issues even with an anti-roll. But the roll was caused because of slack somewhere in the anti-roll.
Post  Jeremiah May 19th 2010, 8:56 pm
Alright thanks.. I might have it figured out. Well find out next time to the track.
Jeremiah
